Hi,
I live in Huntsville, Alabama in the US. I will be importing an R32 soon and want to know which would be a better car. I plan on, if I get the GTS-t, putting in an RB26DETT and eventually getting it up to GTR looks. I will primarily be drifting and heading out to the local drag strip. Which car would be a better buy, an R32 GTR or an R32 GTS-t? The GTR would cost me more at first, but will be AWD. The GTS-t would cost me less at first, and I can upgrade in stages, but will be RWD. I assume that having it RWD would be better for drifting, as AWD is inteneded to reduce traction loss, thus hindering ability to drift. However, I have read that with the GTR's AWD system, it only gives the front wheels power if it detects loss of traction in the rear wheels, and it can be locked in either AWD or RWD modes. Is this true? I would just like some simple advice on the subject.
Thanks
Mazikowski
EDIT: Just on a side note, I am about 6' 2" tall (so around 2m?). How would headroom in the car be for me? Would it be overly tight?
Edited by Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/
well it really depends.. if your going to use it more for drift or drag.
it will be ALOT cheaper to go the route of the GTR. Running conversions and doign things in stages will cost you an arm and a leg in labour/time/parts
plus.. who doesnt want a gtr :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483860
Go the GTR! You can easily turn off the AWD by pulling a fuse or putting in a switch to turn it on or off.
It will be more expensive initially but you will spend more to get the GTSt to anywhere near the same dynamics in the long run.
If it does not have a sunroof you should be right height wise or you could fit lower seats if not.
Thought you guy's could not have Skyline GTR's there in the land of the free :P
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2483956
well, you cant import them really because of laws in states with major ports, but if you import the car w/o engine + engine separate, it can be done, just assemble it in the destination state and off you go... besides, it helps to have some connections :dry:
I should be able to get a GTR for around < USD25k or a GTS-t for < USD15k
plus.. who doesnt want a gtr :O
this is true... OH HOW TRUE THIS IS!!!! lol, sorry, had to get that outta my system
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2484197
If it is SPECIFFICALLY for drift, I'd go GTS-T. Lower purchase price, less weight (AWD hardware is HEAVY!), cheaper to replace parts and body panels (probably).
If it's a powerful multipurpose drag/track street car, I'd go a GTR.
I'm 6ft4 (with a heavy build), and I fit in my R32 GTS-T just fine. But for enthusiastic driving, I'd budget for a new drivers seat and steering wheel - the standard items are under and over sized (respectively) and are pretty much useless for people my size! The R32 GTR seats are apparently much better, but alas I have never driven one and hence cannot comment.
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2489230
Alright, thanks for the info on sizing. I will most likely be using it for both and maybe even some... I guess it would be like circuit? ... racing. Knowing that I can switch between AWD and FWD with a switch ( gotta install first, I know ) makes me wnat the GTR, a bit more power and better car for the most part. Now, to get the money >_<
Thanks
Mazikowski
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492245
Id go the gtst personally, cheaper parts and parts are easly found. with the extra money you will have left if you bought a gtst, you could put it back into your car. dont let the GTR badge fool you I have seen plenty of gtst beat gtr in races on the street and personally, there's not substitute for hanging that arse out when you feel the need to. :O
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2492712
why would it be less expensive? I would end up putting an RB26 in most likely.
I will have to do some more research into it, but I still have a while to go before I would be fully deciding.
why bother with the rb26, go the rb 30, with rb25 top end, its stronger and can produce big hp. and go 1 big single turbo rather then twin turbo.
with the bigger engine, and reduced weight (not having a GTR) = :)
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2493346
but how hard would it be for me to get a 30 with rb25 top end? Like I said, It will take some research... thanks for the advice all the same
::EDIT::
Although it has a larger displacement than the RB26DETT, maximum possible horsepower is less, as the RB30 block lacks the RB26 block's internal cast-in bracing, and consequently cannot rev as high due to harmonic issues at ~7500RPM. To compensate, the RB30DET produces more torque at lower revs.
from http://en.wikipedia.org/wiki/Nissan_RB_engine#RB30
https://www.sau.com.au/forums/topic/133936-gtr-or-gts-t/#findComment-2495813
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
