this is my next idea too, i have an r33 rb25det in my r31 daily and want to go to the NEO in the HR30, good to know it fits, do you have more pics??
im interested too! (not actually contemplating)
the NEO 25 has more torque than a Rb20det (I've heard...)
brillinat fuel economy too if driven nice...
  • Replies 46
  • 1 month later...
HELP,
The conversion is finished and I've had the car out for a couple of test rides, and everything was going well untill, I put the stick in first let out the clutch and heard a rattle and clunking noise coming from the rear of the gearbox (front of the tail shaft) but, it only happens betweem 800 - 1500 rpms then everything is fine.
What is this????
I thought the angle of the tail shaft was off so i put some spacers in the middle hanger, but got nothing.
does anyone have any ideas.
  • 3 weeks later...
HELP,
What is this????
did you fix the problem?
stuffed uni joint??
  • 3 weeks later...
I fitted an rb30et to an mr30 with all standard manifolding, customised gearbox xmember and customised engine
mounts. sump clears and so does the plenum. Its possible to make it fit if you wanna muck around for a couple of
days.
hrmm. ok. well when i put the rb26 in my dr30 the only thing i had issues with was engine mounts. a local xmember is better or a non turbo one. as the mounts are paralel.
i basicly uses the factory rb engine mounts. i had to make a custom gearbox xmember. and tailshaft. (rb25 box)
ive stiill got the shaft kiking around. the selector lined up fine.
wiring wasnt an issue. (aftermarket ecu)
the driveline angle wasnt perfect but. (couldnt get the box high enough and the engine low enough) so slight vibration was felt
  • 3 weeks later...
i'm wanting to put a RB26 in mine... can it be registered in Vic? and it doesn't sound that hard a job labour wise
putting the engine in is only half the fun, its the other things that you end up needing the do to get it right, suspension, brakes, fuel, intercooler and exhaust....
then theres the things you find out later, like the brakes you need to run are to big for your current rims....
z32 brakes all round with a five stud conversion and 17inch rims
already has a 3inch stainless mandrel bent
Rb25 box
larger fuel pump (gtr in tank should do the trick)
then...... comes the fun stuff.... engine management....
  • 7 months later...
Guys,
Sorry its taken me 6 months to respond. I've been away.
However here are some pics of my Rb25 neo in a 4 door 1984 MR30.
Some things i should point out.
Engine Mounts - I got mine off a VL commodore. One is longer than the other. Engine seems to sit upright though.
Radiator - The RB series motors have both water inlet and outlet on the same side. Requires a custom hose, or custom radiator.
Electrics - Some things will not match up. Rev meter for one, and temp sensor is a little off range. (when your guage hits C it means you need to pull over)
Knock at low RPM - Still have not figured this out out. Going to put it up on ramps and check out all the angles this week.
Power Steering - I had a chat with a mechanic during the week about the power steering because I still have the power steering pump off the R34 front cut, he seems to think that if you make up the pipes to the MR30 power steering assy, and hook up the resevoir, it will work. Its just a matter of adjusting the screw on the back of the pump to suit the MR30. if its to light turn the screw out, vice versa (it has to be better than nothing)
There are a few other little things as well like relay wiring for the radiator fan, and why the warning lights on my dash still come on. But its just a matter of spending some time with the wiring diagram.
If you guys want any more pics just let me know, I promise it wont take six months this time
Thats a nice install, well done! So much room to work on. you gotta love that.
I had no problem with the tacho. Mine works fine with the rb30et factory ecu.
Only thing i have trouble with is the water, but i just use an aftermarket guage for that.
Well I'm going to go out on a limb here and take the possible flaming that goes with it but...........keep ya RB motors for R31/32/33/34's and leave the DR's alone, the FJ is what they are born with and should be left as such, if u want to put an RB in something put one in a Pintara, cheap to buy and come with great seats :thumbsup:
Well I'm going to go out on a limb here and take the possible flaming that goes with it but...........keep ya RB motors for R31/32/33/34's and leave the DR's alone, the FJ is what they are born with and should be left as such, if u want to put an RB in something put one in a Pintara, cheap to buy and come with great seats :D
you tell em!...... Its like taming a wild animal in my opinion. They way the Engine delivers the power in one word is PWOARHHH!!
Wouldnt a CA18DET be a better option to drop in a pintara? seeing the have an CA20, wouldnt it just be a pretty straight forward swap from CA20> CA18DET???
Im personally not buying a 6 until I get a 32 GT-R for my collection
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
