yep fred from pro trans did the box for me i think its gonna be a big difference especially with the trans brake neva used one .. has anyone here used a trans brake whats it like...
Edited by campbell
  • Replies 74
the hardest thing about using a transbrake is getting used to not hitting the brakes when you hold it flat but its easy
just get into stage hold the button until you hit the right boost or rpm
i leave the line at 5000rpm with 10 psi boost
any questions pm me
put a boost gauge and 5" rev tacho close to ur steering wheel so u can c it straght and clear. I have 3 speed in mine. 1st u switch your transbrake solenoid on, hold the button then rev it to 5,000 or something, boost will hit 15-18psi. leave the button then you'll get "quickest launch ever". dont hold that button for too long, 5-6 sec max, other way u will cook ur trans. get a big trans cooler !, and dont press it again when you launch, your trans will go back to reverse and brake ur auto internals. autos are jsut like a tune and engine, you need correct stall size to suit ur turbo, and cam and then retune it to match everything... very hard man. You bought the best auto for drags, good luck
Love the sound of the T51R, always have and probably always will :P
As for being the quickest, I'm not sure about times but there was an R33 running a factory-capacity RB25, making 795rwhp getting around Brisbane, was built by Hardcore before they ceased operations and had NIS33 on the plates. Also, 40RCD (now TRY09) might be worth checking too, I don't know if it still runs an RB25 bottom end but last time I saw it, it was running some very decent times. It was definitely 2.5 litre when it was running mid 10's, and I'm fairly sure it was still 2.5 when it broke into the 9's too, but I don't know about now :)
Best of luck ;)
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
