After owning the car for a couple of weeks, i noticed that gear 2 was getting rough to shift into and on a couple of mornings i couldnt shift into 2nd until i came to a stop and went 1-2.
Yesterday I explained the problem to re customs (victoria) and they flushed the gearbox oil with a special liquid and filled up with redline
Today in the morning, i let car warm up for 1min and then went onto my street, gear 1 ~ 1500rpm, tried to shift into 2nd and didnt allow me.
Pull over to side of road and start off in 1 and try to 2nd. No luck. Pulled to side of road again and tried once more, this was after 7mins of engine running. Gear 1 then i manage to crunch it through into 2nd. Engine temp was normal during all of this process. Then i just decided to take off on 2nd and avoid all of the 1-2 hassle.
Now for the rest of the day, gear 1 to gear2 goes in but there is still a slight resistance shifting into 2nd. Although much less noticeable after the service.
Is it common for the cold mornings to cause 2nd from not shifting in? Thought the oil change would have fixed the morning problem but doesnt seem to.
Workshop says $300 for syncro's + $800 labour. Should I make this my highest priority before i even think of any mods? ie. instead of finishing off turboback exhaust.
Thanks
https://www.sau.com.au/forums/topic/134496-cant-shift-into-2nd/
The car's getting back at you for putting that awfully big wing on it.
Crunching = synchros are gone. On a cold morning, the gearbox isn't lubricated at all so don't expect it to let you into 2nd.
Don't expect it to get better either. Make it a priority if you don't like the idea of a 4 speed transmission.
It will get better. You only had the oil put in a day ago...so you need to give it time before it starts doing its thing.
Until then, try double clutching into 2nd, and higher revs will help it in as well...
As for taking off in 2nd, you'll be needing a new clutch if you keep that up
yeah mine is a carny to get into second when cold, thought it was something really wrong, crunched it a little the other day :S but never does it when the car has wormed up for about 3 mins.
how much would it cost to fix a synchro?
Try when cold working out what RPM will allow it to move from 1st to 2nd easily.. for me it's 2,500 rpm.. anything else and I have to just hold it there till it slots in..
remember, just because your engine is running doesn't mean your gearbox oil will warm up.. takes atleast 5 mins of constant driving before it'll start to warm up..
I also agree with Dezz... let the oil get through.. if after a couple 100km's.. think about rebuilding..
Edited by Links
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
