After owning the car for a couple of weeks, i noticed that gear 2 was getting rough to shift into and on a couple of mornings i couldnt shift into 2nd until i came to a stop and went 1-2.
Yesterday I explained the problem to re customs (victoria) and they flushed the gearbox oil with a special liquid and filled up with redline
Today in the morning, i let car warm up for 1min and then went onto my street, gear 1 ~ 1500rpm, tried to shift into 2nd and didnt allow me.
Pull over to side of road and start off in 1 and try to 2nd. No luck. Pulled to side of road again and tried once more, this was after 7mins of engine running. Gear 1 then i manage to crunch it through into 2nd. Engine temp was normal during all of this process. Then i just decided to take off on 2nd and avoid all of the 1-2 hassle.
Now for the rest of the day, gear 1 to gear2 goes in but there is still a slight resistance shifting into 2nd. Although much less noticeable after the service.
Is it common for the cold mornings to cause 2nd from not shifting in? Thought the oil change would have fixed the morning problem but doesnt seem to.
Workshop says $300 for syncro's + $800 labour. Should I make this my highest priority before i even think of any mods? ie. instead of finishing off turboback exhaust.
Thanks
https://www.sau.com.au/forums/topic/134496-cant-shift-into-2nd/
The car's getting back at you for putting that awfully big wing on it.
Crunching = synchros are gone. On a cold morning, the gearbox isn't lubricated at all so don't expect it to let you into 2nd.
Don't expect it to get better either. Make it a priority if you don't like the idea of a 4 speed transmission.
It will get better. You only had the oil put in a day ago...so you need to give it time before it starts doing its thing.
Until then, try double clutching into 2nd, and higher revs will help it in as well...
As for taking off in 2nd, you'll be needing a new clutch if you keep that up
yeah mine is a carny to get into second when cold, thought it was something really wrong, crunched it a little the other day :S but never does it when the car has wormed up for about 3 mins.
how much would it cost to fix a synchro?
Try when cold working out what RPM will allow it to move from 1st to 2nd easily.. for me it's 2,500 rpm.. anything else and I have to just hold it there till it slots in..
remember, just because your engine is running doesn't mean your gearbox oil will warm up.. takes atleast 5 mins of constant driving before it'll start to warm up..
I also agree with Dezz... let the oil get through.. if after a couple 100km's.. think about rebuilding..
Edited by Links
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
