i went to tint a car....far out they want 280 for 2 windows screw that.
primier tinting wasnt even open the losers...when it says they should be.
i need some more info on this VIP tinting
buy a membership and get it done through the club and it will still be cheaper than anywhere you go around $220. my 2 cents :D
https://www.sau.com.au/forums/topic/134544-window-tinting/#findComment-2501647
id rather do my research then just become a member to find out its not dat great.
turns out i have tinted glass not windows......and its real dark
im trying to match that....with tint but its just to dark so something neeeds to be done.....
and i dont know if this VIP can even do it.
wat did other 34 owners do...did ur cars come with dark glass?
https://www.sau.com.au/forums/topic/134544-window-tinting/#findComment-2501663
Well why are you posting here?
www.yellowpages.com.au
I think this will aid your research far more than posting on a forum... which (incidentally) has all the information if you cared to use the search button :sorcerer:
https://www.sau.com.au/forums/topic/134544-window-tinting/#findComment-2501670
I own a R34 GT-T Sedan and all the sedans I have seen come with dark window tin on the rear window, back seat windows and then the front seat windows are not tinted.
I was looking at getting them tinted but figured the dark tint on the back is prob. illegal darkness in oz to be put on the front.
Drew.
https://www.sau.com.au/forums/topic/134544-window-tinting/#findComment-2501846
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
