hey guys, ive been trying to get my car started for the past 2 days and still no go. first i thought it was the battery because it was dead and after i had charged it, it wouldnt take any load. i then changed the battery and still the same prob.
anyone ever had a problem like this before. to me it seems like its electrical because its firing but kinda sounds like something is cutting it off as it starts.
Thanks, Mike.
https://www.sau.com.au/forums/topic/134828-car-wont-start/
Does a fuel pump have a fuse?Did you check for petrol? :laugh::laugh:
Sound like an electrical short ...check coils and plugs.
Then check if you can hear your fuel pump working.
Also sounds like a blown fuse...check your fuses.
https://www.sau.com.au/forums/topic/134828-car-wont-start/#findComment-2506619
failing that, disconnect the AFM and then start it up with half throttle. If that works, you have a dead AFM.
Turn it off afterwards, cause you shouldn't run it for long like that.
Edited by RANDY
https://www.sau.com.au/forums/topic/134828-car-wont-start/#findComment-2507319
Could be no vacuum in the aac valve, at the back of the plenum near the bulkhead
if it sticks open it can cause a vacuum leak at low revs and cause a stall, or it could stop it from starting at all.
Hey mate, are you saying that my aac valve could be stuffed or something in my plenum?
https://www.sau.com.au/forums/topic/134828-car-wont-start/#findComment-2510019
Heres a DIY from these forums
Normally this wouldn't cause your car to not start unless there was consistently no vacuum, however I recently had some issues with Idle hunting and occasionally the car firing but not starting, and this seemed to solve my problems.
http://www.skylinesaustralia.com/forums/in...110431&st=0
Edited by Mike_
https://www.sau.com.au/forums/topic/134828-car-wont-start/#findComment-2512160
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
