i have brand new set of king springs to suit r32 gtst for the rear
havent been used because i have since bought coilovers
paid 130 for them
im open to offers around the 100dollar mark
0438551785
https://www.sau.com.au/forums/topic/134845-r32-gtst-rear-king-springs/
auto barn only listed one king spring for r32's they told me its 30 - 40mm lower
any lower and u wont have enough travel and u'll hit the bump stop
  • 3 months later...
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
