hi there
i have a AP engineering apexi power fc on the way to suit rb20det - only problem is - i know that the loom is slightly different from 32 to a31 and sensors possibly
good example is afm on ceffy is direct fit to z32 with afm plug having the rectangle one...
WILL THIS FIT STRAIGHT IN AND RUN - or what do i have to do? :S get a 32 loom ( i f**king hope not)
https://www.sau.com.au/forums/topic/134887-power-fc-in-cefiro/
should fit in fine...
put it this way
i had original cef loom...
put in an r32 complete engine... retained loom and ecu... just chopped coilpack wiring loom thats all
btw i hope you got it for under 1300 huddy with handcontroller...
i had a AP engineering one in mine, no probs :D
PS, anyone with a stock Cefiro AFM, sell to me, cos the 32 one im using (using 32 plug on cefiro loom) is just shitting me to tears :P
also need to retune my stock computer (in which i think is a 32 computer too). will all this work together once its retuned? or will i need to change stuff around, as since ive put the comp and AFM in its idleing around 3 to 4k :S
Edited by A31cefiro
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
