  • Replies 50
Posted Images
yeah i was like wtf when i saw his setup...
maybe he turned the core upside down or something...
the reason he Beef did his intercooler piping like that is so that the air
that goes into the throttle body is cool, as it doesnt pass behind the radiator like most kits
which makes the intercooler piping warm/hot. The way he did the pipework is really good.
' date='19 Sep 2006, 09:38 PM' post='2510969']
it might help it a little bit.. but it still passes over the hot engine, heating it up again.
ultimately you want a custom/gtr style plenum that takes the air in the front of the plenum, and doesnt pass over anything warm/hot.
like this..
ever touched a top radiator pipe? the one thats basically touching the intercooler pipe on the photo you posted.....they get farking hot :woot:
I don't think it really makes much difference..the air is travelling pretty quickly...so its not going to get much chance to heat up
Ive seen an R32 do the pipes like that before, very very nice IMO.
Here is a thread from the Stag forum.
http://www.skylinesaustralia.com/forums/in...c=92828&hl=
I would have done it like the guy above, but that way uses a few more pipes etc and would have ended up costing me a fair whack more, as i couldnt retain ANY of the stock piping.
id dare say the rocker covers get a tad hotter than a radiator hose, not to mention a fair bit more surface area.
there is going to be hot parts where ever the piping is routed, but minimising the length/hot points it passes is ultimately going to give you the most power and response. :woot:
but with beefs way it passes over the engine before the cooler and heat transfer via convection (dominant mode of heat transfer) is proportianal to the difference in temps.
so as the hot pipe passes over the engine it doesnt absorb as much heat as the cold pipe going over the engine in the normal setup.
if the air collects the heat on the hot side, it still gets cooled by the intercooler. if it is heated on the cold side, there is not chance for further cooling.
id say the effects would be fairly small, but the theory is there still
yeah, but then it wont cool down to as low a temperature as it passes through the intercooler >_<
either way, its good to see people not taking the standard approach to engine mods..
i was wondering if it had any affect on lag or anything as opposed to the tradtional RB25 intercooler setup.
it seems to use 45 degree bends, and long radius 90 degree bends which could help a bit with air flow, rather than the big U shape the typical kits have.
care to elaborate on that, beef?
well the guy who fabricated this set-up said that the traditional "U" shape set-up had a hell of a lot of bends.... he said he has designed a lot of intercooler set-ups with the straightest possible lines and also with the turbo side entering on the left and right of the cooler to see the effects of both.
This was the best he came up with, it is the straightest lines possible on an RB25 and also the pipe going to the intake is marginally cooler when getting to the intake...
his words "this is the perfect, most straight custom intercooler piping ever created for the rb25" :laugh: ha ha he has a big ego....
but i think its justified
Beef
Hey Dezz thats the exact kit im after for mine how long did it take you to do and were there any dramas involved? My car is a series 2 as well What did you have to cut out of the front bar?
Cheers
Chris
Hi there this is my setup everything went in really fast,piping ,fmic just had a prick of a time with the high mount manifold ,so i bought a few ss bends off ebay and made the rest myself this car really kicks as i live in the bush dont know what power it has never been dynoed a friend "reckons " it has well over 220rkw but guess only dyno results tell the real powerpost-30197-1158712585.jpgpost-30197-1158712635.jpg
I don't see whats wrong with the pipework going near the radiator, the pipe gets hot but air is pretty bad at absorbing heat, thats why the intercooler is designed to give a large surface area because it needs alot of air passing through it to cool the intake temp down.
Even look at the CPU cooler on your comp, same principal, maximum area (plus a bit of turbulence).
If air was effeceint at absorbing and losing heat we wouldn't need intercoolers, just run a pipe along the front of a car would be all.
Edited by Rudager
Hey Dezz
Could you post some pics of your intercooler kit with the bumper on??im thinking of going for that type of kit aswell instead of going for the usual hybrid, chinese piping kits etc etc
Cheers
Cheers
Chris
Hey Dezz
Cheers
The pics i posted were the blitz kit on my mates car. We're installing my kit this sunday, so i'll try to take some photos throughout the process and put em up.
Here's a photo with the bar on
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
