http://www.draganddrift.com/car.asp?id=145&UID=0
Seems a little excessive seen as though you could buy them new for $10k less than that. I don't think 623km ever is much of an insentive either.
You could have a bombed out 34GTR for that money. I guess it must be the historical significance....
https://www.sau.com.au/forums/topic/135458-115000-for-an-r32-gtr/
if its genuine youll never find another one again so its worth teh money imo
but what would you do with it? It's a bauble not a car.
It's like people spending $10K on a bottle of wine. They'll never drink it, it's just an 'investment'.
It's a shame really. like taking an animal out of the wild, and caging it for a decade.
LET THE GTR'S RUN FREE
Let them roam in the plains, let them frolic in the gentle curves of the race track, let them hunt down the v8's that are their prey. Do not cage them and force them to smile for the camera!
Thats so cool, so untouched. I cant believe there is still one like it! Says N1!! Id buy it if i had that much cash on me! The km's wouldnt be wound back! Only a fool would wind it back to 600kms and expect no one to notice haha. Its obvious when its that new! Just have a look over it and it will be obvious! Im sad i cant own it!
f**k me! im no proefessor but isnt 94+ an r33? i thought they stopped making the r32 in early 93.
GTST's, yes.
The R32 GTR was made up until September?? 1994. From August 1993 they were all V Spec....I don't know when V Spec II's kicked in though.
*tear swells*
Put perfectly...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
