my new car
Guest Boxhead
ok as you prolly all know, i got a new car, its nice, ok very nice, havent turned it on yet as i looked at it late..
from what i gathered tonight mods are as follows
blitz fmic
cusco front strut bar
nismo rear strut bar
m's K&N pod filter
big exhuast(big to me, could just be 3') - not sure brand
stock interior
Tein coilovers
timing belt done just at 99 kms..
so.. i have some things to do, interior needs a good detail
tryin to post pics, but i think they might be too big.. so will resize and add
https://www.sau.com.au/forums/topic/13556-my-new-car/
Guest Boxhead
im not sure megalla, but it is dead quiet everywhere haha, it will get a good rev or two tomorow :D here are first pics
engine bay
exhuast 1
exhuast2
blitz fmic
rear struts
i couldnt get pics of suspension, coz i guess its set too low for me to really get camera in there etc...
oh also, i forgot, the front brake rotors are slotted :D
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-264239
Guest Boxhead
ok little update, through suggestions of other people, with me showing pics, the front pipe seems to be aftermarket...
yes i turned the car on, sounds very nice...the suspension is height adjustable..
also i have a switch wired to the ecu, but the back of it, here is the pic
http://www.lexicon.net/julieelliott/car/car%20005.jpg
thats where in enters the ecu.. anyone have any idea what it is?
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265400
Guest Boxhead
Guest 87vlt
I think that adjusts your idle. My VL(s) have one - nissan ecu and all ....
Also dude you need and extra 0 in your links ....
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265484
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
