Ok so today i tried to reset my idel, to get the timing correct.
I tried to do what the manual said to do and the guides on here.
Ok warm the car up. Turn off, disconnect the TP sensor, turn the car on, idel is at 1200 rpm, so turn the AAC valve, all the way in, and the car only came down to 900 rpm. Reconnect the TP car rpm drops down to 650. HUMMMM
OK so what is going on, is it suppose to be, i can't sent the timing as it has to be done at 650 rpm with the TP off, but i can't get it that low. Will cleaning the AAC fix this, i have no idling issues, but i am a bit warried taht something is wrong.
HELLPPPP
somone point me in the right direction.
i want to do my idle properly, and same for the timing, and timing seting is rpm dependant.
SO i can't do it properly.
From reading other post, once the TP is off the rpm should drop, but mine rise to 900 rpm and i can't get them down anyfurther.
Ok so here it is then
I turn the car on this morning and still acts thesame, cold start work fine.
Why can i not get my AAC idel screw to bring the idel lower then 900 rpm. Also fideled with the computer screw, and nothing, doesn't make it go up or down, with or withouth the TP set on.
HELP, i think i am going to go insane with this car, everytime i think i have it sussed out and all good, something hapens or i find soemthing new that might not be thesame.
booohoooooooo.
read the thread on setting your idle correctly.
there is also a screw on the ecu yo uneed to adjust usually.
You could also have a vacuum leak, vac leak caused my car to idle at around 1,200 or so
my car idles at 650 rpm, but when i disconnect the TP it sits at about 900rpm, the computer screw does nothing. The thing i am trying to do is tha the base timing is suppose to be set with the TP off at 650 rpm, and i can't get that to happen.
SO i need some help.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
    • Yes, well. Mine are less than half that. ARBs are not set to "dumb" either.
    • I would hope. But, we all know even the best companies have an issue sporadically.
