I used a call out service, Dent Craft. They rolled my front and rear guards on my R33, did a VERY good job. I took my car to him and it was $50 a corner I think. Unsure what it would be for call out.
0409 906 593 Stuart is his name, I think he is based in Ardross, which is near Booragoon.
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2535759
cheers for the info guys...
V&B body repairs in osb park are gonna sort me out
top guys there!
was quoted $50 a corner and the dude there also said he can fit the wheels and adjust the coilover height if need be!
all i have to do is get a wheel alignment done at a tyre shop.
as far as paint cracking goes he said all care taken but he cant guarentee it wont happen
Edited by iz32
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2544574
ah i forgot to add...
i got bored tonite and decided to remove the plastic inner guards as i was told they'd have to do to roll the guards... anyways i noticed on both sides that there are grommet holes with wires/vac hoses/exhaust sensor wire etc.. passing thru them.
do i need to refit the rear 3rd of the plastic guards? to stop water getting into places it shouldnt or is it fine to leave them off altogether??
they come in 3 pieces and are stapled together.
any experiences?
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2544577
Yep Dent Craft got my vote as well, got the guards rolled on the lude for 50 a corner top job.
https://www.sau.com.au/forums/topic/135953-guard-rolling/#findComment-2545479
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
