  • Replies 73
Originally posted by akira
there is supposed to be a home made porno with one of the chicks from Home and away in it. was it her?
I'd do this as "good news/bad news"...
GOOD NEWS:
There is a Home and Away porno (I have it on CDR somewhere).
BAD NEWS:
It's Kate Richie...
T.
Good News: She has massive bagos
Bad News: Her body aint that great
Good News: I'd still bang her
Bad News: I'd probably be taped and put on the internet
Good News: I'd be famous
Bad News: All the women would want a turn
Originally posted by Southo
I'll get my G/F to introduce you if you like, she meets up with bec and they go dog walking together
You'll find that she is not into cars, and actually drives a very non-descript Civic.
Yeah a Black civic with green P's... I have given her a fright a couple times with the supersonic BOV.... :jump:
You were driving next to Bec Cartwright and the best you could do was "Blow off" in her window?
sheesh :P
Well guys i must agree with u about Tammin Sursok, (well how she looks now), i know her and have known her for years now!!!!
She is actually the sister of one of my mates...Shaun Johnson Sursok, Blitz (a.k.a) Nick would know Shaun as he was in our year at high school.
Now what u guys don't realise that a few years ago....about 5 when i was at Shaun's 18th, she wasnt as appealing as she is now! Let me put it this way, she used to pack a few more kilo's back then, but taking nothing away from her she looks mighty fine these days! She actually used to drive a silver VW Golf, and lives in an apartment in Artarmon! She used to live in ST.Ives, but i won't say the exact address, for obvious reasons *cough* Merli *cough* :uh-huh: :P
She also is trying to hit the music world as she can play the guitar and sing aswell......as most of this soapie girls are these days! Last time i saw her...about 2 months ago, she was trying to release a song in the U.K. as the aussie market was full of soapie "singing" wannabe's!!!!
So yeah a little info on this little girl of some of your dreams!
Cheers
Ando
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
