Does anyone know how much it would cost in labour to swap turbo's on a r32 GTR in perth?
I would really appreciate recommendations on which workshops in perth could do this job properly without ripping me off. Besides the cost of the turbos,labour and gaskets, what else would I be up for? I tried searching for a DIY turbo swap, but no joy... cant blame a bloke for trying! :)
Edited by Scratch
I would argue that any workshop will 'rip you off'
there are heaps of competant workshops in perth, do a search, its been covered heaps of times
and yeah, turbo swap on GTR takes some time, even if its a straight bolt on (I assume you have a kit?)
If not, you need to allow for things like gaskets (that may need replacing), studs snapping (hopefully not, rare, but it does happen), silicone pipes and clamps and to top up your coolant.
If you want a quality job, dont try and get work done down to a price, cos in the end, workshops gotta make a few bucks or they wont last long.
there are a couple of places that can do it at a reasonable price XSPEED, TOP RACING ,IMPORTS 101, HYPERDRIVE they are all quality workshops with vast knowledge of imports
If you go Topracing they have moved to a big new shop with 4WD Shootout dyno,New number 94702222.
i knew they were on the move as thats the only place i take my gtr for any work but didnt know when lol
Syslink --
N I B (steve ) works at top racing and its the only place i will ever take my gtr for work (after trying another well known reputable place that could not even complete a normal service in one day properly
http://www.topracing.com.au/ < web addy with new addy n phone number
yes, agree wholeheartedly about getting it done properly by a reputable source. I have recently discovered that the oil return lines back to my N1's are piped up all wrong. The result? Another 4-5 hrs worth of labour to fix!
I met the guys from Top racing the other day ( came into my shop for some quotes on PC gear ) they seem like really nice guys and the know exactly what they are talking about. I plan on taking my 34 to them next year when I pick her up for a FMIC kit + extras.
If your adventurous enough, grab a service manual and do it yourself. All it will be is air lines so no liquid will drip out (Don't quote me on that).
I dont reccomend that !
First you need access to a hoist ,
Second its exhaust side so if you break something it will have to go to workshop anyway.
Thirdly there is oil,water and Air systems to deal with and limited room because twin's take it all up.
I did it once my self and never again with out workshop acceses .....m2c
yeah i have the workshop manual, and figured it might be a bit much to attempt on my own. A lot of good feedback on top racing it seems... might call them up for a quote.
yes Ash and Steve will definatly look after you there :laugh:
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
