well i have a friend with a GTR 33 who has them, but damn dude idd get that if i was you. that gearset is f**ked up good, the consitant harsh engagements that you can make with it. he has about the same power that i have but the way his car moves with that gearbox, damn
The Trust dogbox is arguably one of the worst dogboxes on the market. The RacePace MotorSport 33 GTR lunched 2 gearsets before going to the OS Giken Cross Mission (synchro) box for trackwork.
I know of another R32 GTR that smashed the Trust box on the strip with 450rwkw.
If you're going to run a dog box, go the PPG or if you can afford it, just go with the Hollinger.
i have a second hand fully rebuilt (tightened, dogs re faced, and more tightening) for sale if you want.
i'm asking 5000 ono.
They are actually an alrite box, If like all race type transmissions taken care of and servaced on the regular..
i have had words with the people who actually make them, Quaife in the uk, and he has ran one in his gtr for a long time! and hasnt had problems at all.
Actually I broke it 5 times.. ;) Worst part is you don't even have to try too hard to break it. Broke a different gear each time too,(even the input gears!) so its not like just one gear has a problem. And every one I know of that has actually used one has busted it..They are plain and simply not up to the job!!
i have about 500ps. 2.6L apparently when you go to increced torque they dont like it. increaced displacment is the main cause of this.
tho never had a problem with it untill it selected 5th and 6th and snapped the lay shaft.
this was a problem with them not bieng serviced and tightened.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
