benm, the camera is only a little B&W CCD model, which I bought because it wasn't too expensive and would allow me to pilot the idea of mounting external cameras and mics. Re sound, I have already trialled mics in the engine bay and it's pretty good. I need to build a preamp before I can get the sound and video working together. Once I've done that I'll be choosing a colour camera.
Tex and I had been musing about it for a few weeks (ie "wouldn't it be cool if...") and then I thought hell let's try it, bought what I needed on a friday afternoon and made up the cables. Turned up 20mins late to dinner with a bit of a smirk until I spilled the beans and said I had onboard video and we tested it that night, then I brought it with me on the hunter cruise the next day. So it's very much a prototype :)
  • Replies 40
Originally posted by benm
Well if thats a prototype I want in on the real deal.
Prototype Costs ?
Expected final Costs ?
I believe the prototype was really cheap as chips, though Kinks will be able to tell you more.
No, the real deal is for us. :)
It's going to be quite a bit more expensive, because it's going to be a hell of a lot more elaborate. The camera alone will cost much more than the one Geoff used here... And the ideas I'm particularly keen on trying will call for a fair bit more hardware.
We've not really got a shopping list together, but I'm sure soon we will. :)
Re: sound, we have not only trialled mics in the engine bay with great success now (you will hear an example in my upcoming Hunter vids), but also at the rear bumper, above the exhaust. So far, things look very promising. :)
As Big Kev would say, I'M EXCITED!
Tex
The CCD I used was $110 retail, and I'll be looking at spending several times that amount just on the camera when this idea gets going.
As Tex says the real deal is for us. It's custom work, and will be a lot more elaborate eventually.
Originally posted by Tex
Yeah, yeah, Carlo tells me I'm very close to having heaps of hard disk space (I'm waiting for him to give me the hard drives I need, but he's a busy man :D).  As soon as that's sorted, I'll be editing like a mofo, for your viewing pleasure!
Will most likely update this thread with them, if Geoff doesn't mind. :(
Oh, and Mona, there's plenty more where that came from... ;)
Tex
uh oh!!!
Originally posted by JiMb0
Sweet .... Where's your footage Tex ?
In my pants. Why do you ask?
Seriously though, it currently resides on my camera, awaiting processing. :D As I said before, I am waiting to sort out some HDD space issues, so I can get cracking. Once the HDDs are installed and working correctly, I will now be able to edit pure DV format footage, instead of the other way I've been doing it 'til now, which involves importing in preview quality, editing, and then rendering the vid, at which point the footage all needs to be captured again, in full DV quality to be made in to the MPEG. Then it needs to be converted to DivX to bring the file size down to a more acceptable size.
It's time consuming! At least this way I'll cut one step out of the process, which should cut the total time spent waiting for the computer to capture vid by half.
Tex
DO you think it will be able to be mounted for things like track days etc? Would those speeds risk the camera falling off the outside of the car? This sounds like we are in for some awesome footage on upcoming events!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
