Wanting to put in an intercooler on a RB25DET. Does anyone have any advice?
1) are the r33 gtr and gts-t intercoolers directly interchangable without changing the mounts or piping?
2) is it posible for the RB25DET to make that crazy noise the RB20s in the VLs make? If so, what needs to be done to the engine for it to do this?
Any other general comments are appreciated.
-Enyoy
https://www.sau.com.au/forums/topic/136943-coolers/
The factory GTR intercooler is a great peice of gear, with proven flow ability but for the money, you would be better served buying a complete off the shelf kit from the likes of Just Jap as the GTR cooler will require custom piping and brackets etc.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2544853
A cheaper option is putting an R34 GT-T cooler in. It's a side-mount like the R33 is, but the R34 cooler is thicker and flows a bit better.
If you're only chasing modest power gains I'd do this, otherwise go a front mount kit.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2545064
why would you bother putting a gtr cooler on when you can get new coolers for $150 and cooler and piping kit for $400. and i think you should do a bit of a search first there are many many topics on coolers. also dont block off your bov for that "sik flutter noise" makes you look like a wanker, and isnt healthy for the turbo.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2545095
this would be pretty much a waste of time and money especialy if you live in a hot part of aus.
the reason you would buy a GTR cooler and get custom pipeing is because of flow and cooling efeciancy. cheap kits are cheap kits. they dont flow, boost will drop and cooling is average.
also the cheap kits fit pretty average and most of the time the front bar has to be hacked to fit it where as GTR ones are made to fit.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546053
GTR coolers are mass produced and have pretty poor flow capabilitys, the fins are very close together. also the $600 for a gtr cooler and then bout $400-$500 to get piping made up is goin to be better than say $350 kit from CRD in sponsors section. For most people unless your chasing like 1000hp or something stupid the cheap kits are fine, also the cheap kits have been tested compared to expensive ones and there is like 2% difference. For me $350 compared to over $1000 to not cut the front bar and have like maybe 2% flow difference just isnt worth it and most people will agree with that.
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546074
Is that the kit that requires to chop the battery tray or does it run the pipes through the existing pipes?
Cheers
Josh
I personally dont know what to do to mine at the moment as I have I think to take the battery and get a smaller one but maybe ill run the pipes to the exsisting one... anyone have better ideas?
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546266
actually,the r34 gtt sidemount is good for 200 odd rwkw/awkw and wont heatsoak too badly if you are using a stock/factory option front bar which is designed to flow in that direction. using the factory shroud will also help.
i think for ~$200 and DIY install (easy as piss), the r34 gtt cooler upgrade on an r33 is a great idea. this is what i have done second time around on my stagea, first time being a GT-AH cooler/custom piping :wave:
https://www.sau.com.au/forums/topic/136943-coolers/#findComment-2546418
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
