neither.. not unless it was a jap import - there wont be any australian released ones either.
there are (although quite rare) SR20DE S14s around...
power/speed/weight wise.. similar to an SR20 180 or s13 would be a safe guess
They are around... JDM cars though and few and far between... S15's as eug said are very light so i imigane they would be compariable to a NA 33 or 34, they also got the new version SR with VVt.
NA JDM S15s used to be available in Australia before RAWS came out, don't think there are being brought out any more.
I don't see the point to them, may as well get a faster DC2 Integra Type R if you want a good handling NA coupe with high rev performance. I had a Prelude VTiR before and it was very chuckable around corners and had a strong top end.
Edited by R34 Rampage
Spec S was the non turbo and Spec R was the turbo version in Japan. In Aus, they were both turbo but spec R had better options and a sunroof.
I have driven an NA S15 and that was slow as! Its ok i suppose but the Aus Del turbo version was much nicer. JDM was even better.
Havent driven an NA R34 before so i wouldnt know
You can't import regular N/A S15's (and they weren't sold locally)... BUT you can import Autech tuned N/A S15's. Which come with the Autech SR20DE which makes about 175hp. I wouldn't say they're much more faster than an R34. They cost about $23,000 and more landed and complied (plus rego costs etc).. although they're quite rare at that end of the price range. They're lighter than an R34 N/A, but the R34 has a 2.5L engine that puts out about the same power.
http://www.j-spec.com.au/list/7508
http://www.j-spec.com.au/list/7507
http://www.j-spec.com.au/list/7506
http://www.j-spec.com.au/list/7505
http://www.j-spec.com.au/list/7504
You can also import a S15 Varietta (convertible), but you won't be able to afford one (going by the budget you gave in your other thread).
Locally sold S15 turbo's are around the same price as the Autech N/A's but they're turbos n not good for P platers like you.
Lucky Autech is considered a manufacturer, or otherwise it'd still run afoul of the NSW P-plater laws that say you can't have a car where the engine performance is "modified".
technically as far as DOTARS knows "Autech" is a spec of S15, which is why the Autech N/A's are listed as a variant on the regular S15's :huh: sneaky sneaky :P
technically as far as DOTARS knows "Autech" is a spec of S15, which is why the Autech N/A's are listed as a variant on the regular S15's :O sneaky sneaky :laugh:
My understanding when reading....I can't even remember which magazine, probably HPI.....is that Autech's cars have their own VIN plates. They're not Nissan's. If I remember, it was an article about the Tex Modify tuned Autech Stagea 260RS.
Which makes them an OEM of sorts, so anything they do to the car is "factory".
So, they're like HSV / CSV down here. Those cars don't have Holden VIN plates, even though the donor vehicles are Holdens and HSV / CSV are technically different companies.
THATS SICK!
Meh, i took the easy way out and got a 32 gts. I'm sure alot of people have said this, but i'll say it again. Get a "Shitbox" learn on it, save money then buy whatever you want. Trust me, Practicing on my na 32 is good, i probably would of crashed if i had a powerfull car.
You must be really keen to own an S15 on a "restricted" license if you'll spend $30K on a non-turbo S15......
I suppose you can always sell it when you get your full license to another P plater who wants an S15 shape. Maybe it'll retain value better than the turbo ones for that reason, but your buying market will be extremely limited and P platers aren't generally reknown for having lots of money.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
