I came across this idea from our Victorian neighbours…
I was thinking of organising a monthly pizza night, a chance for the members of SAU living in the ACT to meet and have a good night. So far its just an idea and depending on the reaction received it could become a monthly event.
Time: Could be held on either a Friday or Saturday night, around 7ish, whichever suits most people...
Where: This will change every month, with a new pizza venue being nominated.
We can then ask the people that came to vote and find out what is Canberra’s best pizza joint!
So what do you all think?
Cheers
https://www.sau.com.au/forums/topic/137104-sau-act-monthly-pizza-night/
I'm in! always up for a get together with my crew! (you are my crew in case you didn't know).
wow Ive never been part of a "crew"
Cant believe the response from everyone, this should work out really well... Umm ok stacks of ideas, but a friday night ok with most people around 7 and Zefferellis can be the first pizza shop, date might be set at the end of this month?
Should get off my lazy ass and meet some of you people one day. :laugh:
I even have my very own skyline now :bunny: hehe...
I would be up for a friday pizza thing. altho it will interrupt my usual friday night drinking but I can cope with that
damn, i have training in gungahlin friday nights until 8pm, maybe i could come late, really late... stupid south yass being so far away.
Damn that is a fair drive away but you might be able to make the cruise after, if you drive at the speed limit the whole way...
Should get off my lazy ass and meet some of you people one day. :happy:
I even have my very own skyline now :P hehe...
I was thinking about that too, but the solution is shift your drinking to saturday, if your really keen then just drink after...
Ok well since its Beaus birthday, I might set up the first pizza night on 27th October, say 07:30 at Zefferellis in Dickson - how does that sound? This weekend I'll repost with a proper post giving all the details and a nominal roll so I can book a table or two
Damn i gave back my ACCC pass that got me into the carpark at Transact building. Aurora you would still have yours right you can get us all in it will be empty anyways :P
Sounds good to me.
It'd be good if we could get parking out the front of Zefferelli's but in Dickson on a Friday night.... HA!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
