Took my car in to get the diff tightened, came out with him saying that driveshafts have play in them, so I replaced them today. and my car is still clunking and jerkying around corners on light acceleration..
Now there is for sure some play in the diff when I turn the wheel with the car jacked up the car clunks and I can see there is play within the diff but the guy told me thats just how it is and hes check everything. What can I hit this guy up with when I take it back to him next week. can it be the shims????
Edited by cefiro
https://www.sau.com.au/forums/topic/137904-loose-mech-diff/
if it clunks and carrys on at low speed could it be that the initial torque setting is to high and the diff is not wanting to slip?
yes exactly the clunks are caused because it is locking up - ie too tight not too loose.
I'm sure you could find someone to swap it with a standard lsd if you want something looser
https://www.sau.com.au/forums/topic/137904-loose-mech-diff/#findComment-2578109
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
