Took my car in to get the diff tightened, came out with him saying that driveshafts have play in them, so I replaced them today. and my car is still clunking and jerkying around corners on light acceleration..
Now there is for sure some play in the diff when I turn the wheel with the car jacked up the car clunks and I can see there is play within the diff but the guy told me thats just how it is and hes check everything. What can I hit this guy up with when I take it back to him next week. can it be the shims????
Edited by cefiro
https://www.sau.com.au/forums/topic/137904-loose-mech-diff/
if it clunks and carrys on at low speed could it be that the initial torque setting is to high and the diff is not wanting to slip?
yes exactly the clunks are caused because it is locking up - ie too tight not too loose.
I'm sure you could find someone to swap it with a standard lsd if you want something looser
https://www.sau.com.au/forums/topic/137904-loose-mech-diff/#findComment-2578109
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
