Hi ppls,
my R34 GT-T had its first dyno last week. Im pretty happy my tuner managed to squeeze 194rwkw out of it at 14psi on the std turbo, virtually on the limit. I think he managed to do it coz the engine n turbo is in good knick. Wot do u guys think from the dyno graphs? A/F ratios still safe? Knocks were between 13-20 during the tune i was told, i only give it a squirt now n again, its not a track car as yet, i noticed that knocks were around 15 usually.
Mods - Power FC & boost controller, turbobak with split, FMIC, pod, BOV, plugs gapped at 0.7.
Any comments welcome.
Cheers.
R34_dyno_AFR.pdf
R34_dyno_Boost.pdf
https://www.sau.com.au/forums/topic/138152-my-34s-first-dyno/
at 14 psi, well not sure why but i have an R33 with 73k on the odo, with same mods and i managed 187rwKw at 10.2 psi.
Seams low, but the stock turbo is only good for 12 psi, after that it just pushes more hot air in, as it is ineficient.
My map however looks more like this.
Well done.
Is it just my eyes or is that a VERY rough power curve? Why is it all over the place, especially with a PFC installed? Even stock ECU power curves look more "even" than that.
Won't comment on the power figure, it's believable.
have you ever tested this, or are just saying it because everyone else does? i have the stock r33 turbo running at 14psi, and it is noticably better than 12psi, which i used to run it at. i'm putting it on a dyno in a few weeks time so i'll be able to do before and after runs.
Yes i have, well i have looked at the stock Turbo maps, the turbo will definatly go better at 14 psi, it still flows more air, but it drops almost 36% in efficiency. So you are getting hotter air at 14 psi with lower efficiency, meaning that the turbo has to work harder, hence shortining the life span.
the gain form 12 to 14 psi will be marginal unless you have a very good intercooler.
Having said all that, i don't think anyone has done any dyno runs so this would be great. see what you get.
Forget the whole hot air thing. 12-12.5 psi on the street I think is safe. The fact is that if you run 14psi all the time you will have to be very lucky for the turbo to live long.
Just because your grandma smoked a pack a day and lived to 90 doesn't mean that millions didn't die of lung cancer. No one gives a f**k about the odd one that survives. We just say congratulations, you are rare.
Power is good.
I think the curve is rough because they are both single runs. Dyno operators often print an average run which smooths it out. Also, when you have under 200rwkw you have a higher reolution on the page compared to someone with another 50-100-200 more.
It seems looking at the power flattening and even dipping late in the rev range on the high boost setting that you have a restriction in either the intake or exhaust or both. This is confirmed by the boost dropping off. Are you still running the stock cat? I guess it could also be a crap boost controller. The stock actuator should have no problems holding that amount of boost.
I know what you mean any more than about 11psi in mine and I seem to loose top end, mid range increases but I defently loose top end.
10-12 psi max for dayly driving if you plan a mountain run or a track day 10psi is the max id go.
My R33 made 195.6rwkw at 10psi, dyno dynamatics, shootout mode at ICE performance. Similar mods but I have SAFC instead of power FC
cheers
I'd be asking for a refund on the tune... its pretty average mate.
Certainly needs a bit of work.
The power curve should be smooth, and this would reflect smooth power delivery... you graph is all over the place.
And back it off to 12psi, otherwise you risk it dying.
Some do, some dont... so its your own gamble :ninja:
Some do, some dont... so its your own gamble :laugh:
i agree with what r31nismoid said.
OMG WE ACTUALLY AGREE...yay now im going to the pub to get trashed....
cheers.
i agree. Your power curve is very erratic. The curve is what you'd expect from a std ecu. not a pfc. Put the boost down a little, an if the pfc is tuned properly then you will get more power, and more importantly a smooth power curve, hence a smoother and better power delivery which you will notice on the road.
Also i feel it is too rich at 11.2:1. Try and get it closer to 12:1.
Power is good.
Could my power curve be rough becoz they r individual runs like Abo Bob mentioned? Are those smooth graphs u guys posted a average power run? Just wondering?? Abo Bob - im running BATMBL's 5" body cat so i wouldn't have thought that it was a restriction, also have BATMBL's split dump & a Blitz NUR catback so i would have thought there should be minimal restrictions there. Boost Ctrl is the Apexi Power FC EBC, wouldn't have thought that was crap either. I can't think of wot else could be restricting it :laugh:
Also does anyone have any idea wot the lower graph with Lb on the right vertical axis reads? I thought it was torque at first but after converting Ft Lb(assuming thats wot it is) to Nm, it cant be torque.
R34_dyno_Boost.pdf
Well, you have to take into account that the stock turbo is running out of puff.
it wont hold much more than 12 psi up top when tuned as it simply isn't big enough too.
Torque can be either in foot/pounds or kilograms/centimeter.
Mate; my friend's R34GTT in AUTO with nothing but a Std ECU ran 194rwkw and the curve was A LOT smoother than yours :laugh:
Glad that my immediate reaction from seeing your graph is shared by a few others.
You have a PFC; your graph should be smooth as all hell!
Nope.
I've never seen someone "average" runs and print that out.
Not saying its not possible... But your run is all over the place which is basically a poor tune
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
