on 98 (ultimate/optimax) previously had to pull boost back a touch to prevent higher knocks,
on 100 (extreme/Vpower racing) have been able to re-up boost to as previous yet rarely get a high knock.
(pfc is still tuned to 98 fuel as would hate to get stuck in stix with wrong tuning to fuel available.)
works for me,
john.
tyred on my R33 GTST S2 for the first time about a week ago (shell near garden city), it certainly feels a lot better, no mods just exahust and still stock ecu !!.....
and hense petrol is anyway 10 cents cheaper here in brisy then in melbourne (moved up 1 month ago)..the price still feels better.....
im pretty sure its now called v-power coz thats what its called in europe. sort of a would wide standard.
ps. anyone ever read the "new unleaded" brocher where it "gets you further"
down the bottom it says in a small disclaimer that the fuel used during the test is "diferant" from what is curently available localy lol so yah it doesnt get you further lol
i have a question - I pumped up with v-power today (had a quarter tank of ultimate left). Came to about 33 ltrs - but then it only came to 3/4 tank full :(
would there be something to do with expansion of the fuel or is it just that my guage is stuffed? Im guessing my gauge is stuffed.
Yeah sounds like the gauge is stuffed. Did your fuel light come on though?
nah cos i filled it up when there was quarter tank of petrol....its just wierd - i will see how it goes when i fill it next time (if i get to fill it before my next service). I do know that skyline fuel gauges are notorious for being faulty.
SK
With your head work, have you run it up on the dyno?
Have you found higher power figures, different boost curve, faster or slower to boost, better or worse economy and response?
Thanks
BASS
SK
Thanks
BASS
Hi, not on the dyno, I am road tuning it. At the moment, with the standard turbo, I have 10 psi at ~2,000 rpm because of the ignition advance I can use, +18 degrees (compared ot the default maps) at many load points. As a result the response is lightning fast.
As for ecomomy, it happily runs 15.1 to 1 A/F ratios at cruise (open loop), with absolutely zero hesitiation or surge. So I can confidenmtly change the lambda aim table when I turn closed loop back on.
:( cheers ;)
SK. So headwork is a good option on a car, if for instance you are bored and want to pull the head off and have get it tidied up?
You won't loose any grunt?
without changing valves and all that, do you see it as a good thing to do once you have done turbo, injectors etc etc.
How does it go on the $ / results graph?
Just going back to the title of the thread for a second while we wait for God to respond... I used some of this fuel on the track the other day.
I was expecting to be able to put some more ignition timing in it but knock levels didn't decrease with the change of fuel so I left it alone. I felt maybe 5 more rwkw. However much is the smallest amount I can feel using the seat-of-the-pants-o-meter.
  • 1 month later...
As postred in the other thread where you asked the same questions
Been using 100 ron in the R33GTST since January (almost 12 months). I put an adjustable FPR in recently to raise the fuel pressure and a GTR fuel pump. I checked the fuel lines at the same time and they are in perfect condition.
:D cheers :D
is it me or why do i still think that my car feels nicer and smoother and 'quicker' on Vortex 98 even compared to V power racing?
Car: R33 gts-t (auto) with basic mods
my best mate with a stock R33 Gts-t Manual has the same opinion?
Edited by dineth
  • 3 months later...
ive been running vpower now 4 about 2 months in teh 1st week the motor started to run cleaner rev more freely and this improved all week. ive gone bac and tried ultimate etc and
also fuel economy when drivin normally (not v often 4 me lol ) has improved (550 km per tank good? )_
those out there using the ethanol blends from the discounters beware there some dodgy servos (no way ? :( ) out there upping there eth blend to cut costs........
:rofl: cheers :rofl:
So have I. seems to be great.
I have a 100RON joint near my house..I only drive the car 1 time per week so the extra cost means nothing to me.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
