  • Replies 57
BIG MOTHER F#$KER THAT THING IS
The massive amount of exhaust gas the 20B pushes will make light work of that turbo. Nothing sounds like a 20BT on full song, tough as all fark. Such a gruff, pissed off sounding engine.
how will the auto go with the haltech? or can you leave the stock ecu there to control ign and ign cut on gear changes?
Stock ECU will still control the auto - with the Haltech controlling everything else.
That is.........
until the manual converion :thumbsup:>_<:happy:
I dunno Adrian - I thought about that, but.....
It's not going to be purpose built for drags, and
I like driving a manual bettern, and
Manual Cosmo is more Unique.
It's about the same cost.......
manual, good plan b-man.
i forgot, did you get the 60mm GT-II or 50mm? and how much was it?
it's going to rock the house, no doubt about it.
GT-2 = 60mm - and was good price from BD4's - very good......
Manualised Auto - fun to drive AND good for drags.
They are awesome wastegates...well in looks anyways....I havent put mine on yet !!
Should be on the car in a week or so....cant wait either :rofl:
Btw if you dont mind me asking how much did you pay for the GT2 wastegate ?
Im sure my dude got it for me cheaper than BD4s...but hey maybe you have a good relationship with them :rofl:
PM me if you dont wanna say on the thread...
oh and 2 1/4 inch screamer FTW :( I got the 60mm also :rofl:
  • 5 months later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
