Suspension/Steering
2x Front Stock Sway Bar - $30ea
1x Rear Stock Sway Bar - $30ea
1x Castor rod with stock rubber bush - $50
1x Castor rod (bent) with aftermarket bush - $30
1x Aftermarket castor rod bush - $30
1x Stock rubber castor rod bush - $20
2x Front Hubs and Upper Control Arms - $150 for pair
2x Front Shock Absorber - $50 for pair
1x Steering Rack - $70
2x Front King Springs - $60ea
Front shit
1x Horn, can be hooked up to any car - Make offer
1x Front Left Gaurd (damaged, is bent slightly, and crumpled a little bit on the inside) - $50
1x HICAS Steering Pump (i think) and all the lines to go with) - Make offer
1x Stock Intercooler Piping - Make offer
1x Front Bumper Reinforcement Bar (has small dent) - Make offer
2x Headlights (right side one has snapped mounts) - $100 for pair
2x Indicators (right side is cracked a bit, but works) - $30ea
1x Radiator (damaged, small dent) - $20
1x Air Con. stuff, condesor, lines, bottle etc at the front (condensor is damaged in bottom corner) - $20
1x Master Brake Cylinder
Misc stuff
2x Stock Clutches, 1 half warn, one fair bit more warn - $50 and $100
1x Stock Rear Spoiler (with brake light) - $50
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x Stock RB20 Fuel Pump - $50
2x Slip-on (floating) spacers, 8mm thickness, PCD: 114.3 multi-stud 4/5 stud - $30
1x 3" Catback Exhaust with 2 mufflers and 3" polished tip - $100
8x Stock GTS-t rims - $70ea or $200 a set
4x GTS Type S Rims - $100 set
1x Power Window Control Panel (buttons are kinda fecked) - Make offer
1x High Performance 3.5" CatBack Exhaust
1x RB20 Turbo
Tires
2x Falken Ziex ZE-326 - 235/45 R17 - basically slicks in the middle lol, good for drift or burnouts etc - $10
http://img529.imageshack.us/img529/8844/tires1hy9.jpg
1x 205/65 R15 on commie stocky 5 stud steelies - not much tread left, would be good for spare tire - $10
http://img212.imageshack.us/img212/2962/tires4pb0.jpg
4x Goodyear tires - 235/60 R17 - bit of tread left, not much, alot of camber wear - $20
http://img103.imageshack.us/img103/7929/tires5rb3.jpg
Theres more shit, i cant remember it right now, MOST PRICES ARE VERY NEGOTIABLE!!
ASK FOR PICS IF U ARE INTERESTED
Located in Mitcham/Unley area in SA
Edited by nisskid
  • Replies 65
Do you have pics of the following:
  • 1 month later...
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
