Okay, so first gear pulls hard, all the way through, can rev it right to limiter if pleased. Although second, rev's to around 3.5k and it starts to stutter, and VERY slowly moves up to 5-6. Same will all other gears. 1st gear still pulls hard, right through the rev range. Neutral, rev's above 3-4 easily. Just 2-5, any ideas?
Thanks guys.
https://www.sau.com.au/forums/topic/138454-any-ideas/
Thanks guys.
Clutch slipping?
https://www.sau.com.au/forums/topic/138454-any-ideas/#findComment-2578349
love how people say rich and retard before asking what ecu. also it sounds nothing like rich and retard. rich and retard is a violent stop/start. i used to get it happen on cold mornings.
sounds like you have a spark issue. either coils or plugs. does it sound as if you are hitting a limiter? if so then it is a spark issue. how old are the plugs? and what sort? if they are iridium pull them straight out and get nice cheap copper ones. about $4 each and seem to last longer and run better than iridiums.
https://www.sau.com.au/forums/topic/138454-any-ideas/#findComment-2583241
