Hey guys thanks for all the replies but unfortunatley found out that the timming belt have been chewed up badly by the cam gears...You guys r right(blind elk, and MBS206)F*@$k..Should i still hope for the best? can it be fixed?? Anyone from victoria south east suburbs that could point a mechanic expert or after hour job that dont charge like gold?? Again really appreciate all your input thanks y'all..
Sorry to hear :laugh:
BUGGA.
Probably cheapest fix is to get a new engine from a wrecker - try John at J&S Imports in Seaford, 97750597. Talk to Daniel - 98082590 - (he's in Burwood) about fitting the new engine.
Tell them Greg sent you (and they'll happily double the price LOL)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
