Can wait for it to run out, can change it as soon as you get there, don't 'have' to change it at all if you go about it the right way, it's all up to you really and how well you want to follow the rules :) generally your 'supposed' to swap the rego over within 3 months.
They will just do a VIN check to change over rego - unless your car is blatantly illegal from the outside, they will not defect you .... but either way my knowledge is you don't have to do a full Regency inspection (which is an absolute nightmare).
Yep can verify that too you dont even need to take the car with you no vin etc etc, as long as the car still has current rego and is in the name you wish to change it too. my car wasnt even goin then (still isnt lol not long now but).
This only applies if you're buying a car from interstate .. not transferring nsw/sa registration (i wouldn't have a clue about that).
When i brought mine over from victoria, i need a Vehicle Identification Check (about $25 dollars) from Regency. They inspected the car, and although it's not a full inspection, i was not allowed to have a turbo-timer or boost controller installed (see my old thread from julyish).
Then you take this slip to RTA, and you pay your stamp duty and then you pay registration and collect your new plates.
100% sure Andrew. The car was already in my name in NSW, came here, went into Motor Reg, said car was in my name, already registered, they just presented me with a form, filled it in, payed a couple of bucks and bam, all done :w00t:
Yep can back that 100% as i said before i rang up sa transport and they said if its in your name and has current rego just bring in the old rego slip and they change it over no checks nothin, and true to there word took in the old rego took bout 20mins and i was walkin out with my new rego and plates (they didnt even take my old plates which i was very very happy bout).
Didn't take my NSW plates either, but when I rang up the RTA in NSW to get my refund (still had 3 months rego) they said that Motor Reg down here shouldn't have even given me the SA plates before taking the old ones
Yeah this is what I also had to do when I bought my car from Sydney, though I didn't have to go through regency as I lived further south. They have a special check station next to the Sturt cop shop. I had a turbo timer on it , that wasn't really hidden very well but wasn't noticed & some very illegal tinting (since been changed) which was simply noted that it didn't comply, never heard any more of it.
They basically just check the plates & the engine number to see if everything matches, not much more than that.
ah well things have really changed then. When I brought my MX5 back with me when I moved back here from Darwin I had to take it to Regency for a VIN check, and while I was there they made me pull off my illeally dark tint there and then. He handed me a razor blade in a holder thingy and said I couldn't leave until the tint was off.
I had the same thing when i bought my RS260 from queensland in feb this year, the car was already in my name but i still had to take it to regency for an identification inspection, they checked all the numbers then had a basic look over the car. I got told my tint was too dark aswell and got handed a blade to remove it, i had to remove the tint from the whole car, but lucky for me the only windows tinted were the drivers and front passengers windows, the rest is black glass!
But the point is, the car was already in my name and i had to do it within 14 days of bringing it over. AND queensland reg sent me a letter asking me to return the plates.....which i never got around to come to think of it!
I brought a car form NSW when still living in Adelaide. Its a simple procedure and it was a different shed then were the defects get done at regenecy and all they do is check that the Vin number is correct and they didnt even look over my car. They just gave me the new paperwork and I was on my way. very simple I also wait till my nsw rego had run out as a pain to try and get whats left of rego back need to write a letter and all sorts....
If you own the vehicle interstate and it has current registration you don't need an inspection. All you need to do is fill out a form and get some new plates like Luke said
I'm certified to register vehicles, and i used to look after interstate used registrations
as for calling you get a call centre that doesn't know shit. We always get customers that have called them brought the "correct"information in and it will get rejected by the registra.
Edited by Whiplash
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
