hi
thinking about upgrading my turbo
need to go as high as 800hp +
fast spooling when use with rb30
which brand makes good turbos without raping the wallet ? may be something that can compare to a HKS To4Z or T51Kai ??
How are the pricing for turbonic turbos ? are they cheaper then HKS and the quality as good ?
when i look at a turbo sizing, how do i determin what kinda power out put it has ? how do i tell how fast it will spool ?
thx
__________________
https://www.sau.com.au/forums/topic/138829-single-turbo-help-800hp-goal/
800hp @ the wheels will never spool quick even on a rb30
a T88 could do that but your wallets gonan get a raping
is this gonna be a dyno queen or actually driven daily/track/drags
how are you going about with the Rb30? parts, rough price, which workshop? im lookin at getting one built with a rb25 head (been quoted between 7k to 10k by various workshops, sound approx right?)
Will be looking at t51R spl on about 45psi boost, no i am not joking. or Turbonetics Y2K on a bit less. I looked at the Y2K but the smallest exhaust housing is still way to big. this will definatily be a track car only and expect to run atleast 100 gas to spool it on the brake.
hi
thx
__________________
hi
i am not looking for a twin turbo FAST SPOOLING, but i just wana compare, which is faster between these single turbos..
i am planning on a Track / street car...
Gary "sidneykid" is building my RB30 with a 900hp compatible range.
head is only 272cams + tomei springs and retainer kit and valve guides
turbo is T78..but looking to upgrade, greddy in-plenum.
etc...
Have many people on this forum tried getting tricky and using one of those MrTurbos cores? This guy, in Sydney i think, makes CNC cut watercooled ballbearing cores and shafts, which give you almost any choice of turbine and compressor combo!!
I saw some scary 1500hp setups using his cores, advertised in an American sports compact mag few weeks ago as well.
I know of at least one person lurking on these forums with one, are there any others? What did you use, how did I fair compared against stock unit?
- M
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
