Hey guys,
Considering a Sliding high flow RB25 jobbie, and read the modifications sheet required for this. Now, I don't know about you guys, BUT the stock oil/water lines on RB25's are PATHETIC.
AND being that I want to upgrade the turbo, and putting it in has to be less of a headache than it was before (Yes, I was spoilt, I installed a HKS 2535 which came with everything I need)
I want to replace the stock oil/water lines with braided ones, already pre-modified ready for this turbo!
Has anyone purchased new braided oil line for these turbos? If so, where, how much?
Has anyone bought applicable water tube and fittings for these turbo's ? as above?
Cheers,
-Kym.
This is where you find out how it can be easier with Hi Flows based on the original housings and bearing housing . Because it is dimensionally identical to the factory turbos the GCG Hi Flows go bolt with ALL the factory hardware .
I think its a big call to claim that the factory oil and water lines are pathetic because in normal service they virtually last the life of the engine . Its no surprise that they don't fit non standard turbos - they wern't designed to were they ?
Its a different story with "turbine kits" like HKS etc make up because they've worked out the fiddly bits to make all the parts "fall" together . Like Sk says , Japanese work shops charge like brain surgeons so the faster it all fits and works the less time there is to pay for .
Cheers A .
What I mean, is the stock lines are metal, dont bend, and are a pain in the ass to remove/refit turbo's to!
I'd much rather replace them with PROPER larger diameter as required by the highflow's to begin with.
See my point?
Sliding performance turbo's bolt up directly to the standard oil and water lines which as Disco said are more than capable of doing the job.
The modifications are set out to prolong the life of the turbo as they are not ball bearing like the other compies which are twice the cost.
I dont think that spending the extra dollars on the braided lines will give you any increase in reliability over the stock oil and water lines.
They were designed to do the job and handle it rather well under all conditions that i have seen.
:rolleyes:
You gotta remember he is taking a step backwards... ball bearing to bush.
So it will need more oil.
Purple Pig/Enzed/Pirtek all do them Kym. Shouldnt cost you more than $150-$200.
Just take everything down there so they can match bolt sizes etc etc.
Usually the employee's know whats going on. Im yet to have issues here in Melb with above places.
I agree, i went to enzed and they were able to hook me up with the bandjo fittings etc etc and they were very helpful :D
Strich9,
I know where your coming from. That inside banjo bolt are a pain in the arse. I've removed the turbo on mine a total of 6 times. :( I have got it down pat now though so its not so bad.
For the cost of braided lines..... I'm not sure its worth it. Remove the top oil first then bend it up slightly, then remove the inside banjo and its not too stressfull. :D
If its tight don't forget to grab a trusty open ender and ring spanner that you can slip in to each other to give you some decent leverage.
Ah, holy crap 150-200!
You're right Cubes, for that amount of coin I can f*ck around with it.....
ps Cheers Ash - but I don't have the stockers out my car yet :(
[Michael] Do you have part numbers that can help?
nope sorry, i just went in with the stock lines...
i might still have all the stock rb25 lines and stuff laying around in my backroom, if u want u can borrow them so u can just go in with them before u take ur trubo off!
I have to agree. have taken off 4 turbos and the water oil lines allways cause me dramas.
I would like to have some flexible ones made up as every time I have upgraded from an RB20/vg20 turbo to a RB25 turbo something did not fit.
like larger diameter banjo bolts.
I am going to be getting a new turbo and think I will try to get a second set of lined and mod them before I take a spanner to the car. Nothing worse than getting it all off and finding out you have to get some emergency very costly work done to get it all to fit.
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
