Man I'm stupid, finally figured it out. All the pics I keep seeing of the 350gt-8 are the 2001/2002 models. Mine is a 2003 and has had a few changes. I found this on the nissan global site:
Skyline Sedan Undergoes Minor Model Change
Among the refinements made to the Skyline Sedan this time, the 2WD models now have higher spring rates, shock absorbers with approximately 30% greater damping force and larger-diameter stabilizer bars for better control of body motions, compared with the previous models, and thereby deliver a tauter driving feel. In addition, braking performance has been enhanced by adopting a braking system incorporating high-performance sport brake pads with an increased friction coefficient and highly rigid brake rotors with an outstanding heat radiation characteristic.
The exterior design projects a sharper impression than before as a result of applying a smoky chrome finish to the grille and headlamp inner panels and changing the sill color from gray to black. At the rear, the car badge and Skyline emblem have been repositioned to give the rear-end a wider look.
On the inside, the audio and heater control switches have been embellished with a chrome accent for a higher quality image, and the 250GT and 250GT FOUR models are provided with rear-seat air-conditioner vents for enhanced occupant comfort.
The grade selection has also been reorganized as part of this minor model change.
<Major specification and equipment refinements>
Exterior
Repositioning of the rear car badge and Skyline emblem
Refinement of the design of the radiator grille, headlamp inner panels and sills
Addition of Sparkling Silver Metallic and Rose Red Pearl as new body colors for a choice of six attractive colors altogether
Interior
Refinement of the control switch design
Adoption of sun visor extensions
Addition of a light to the front-seat vanity mirrors
Adoption of a double-pivot rear-view mirror
Expanded application of rear-seat air-conditioner vents to the 250GT and 250GT FOUR models
Mechanisms
Refinement of the suspension and braking system
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2591299
yeah i saw one of these on the road a while ago, and it threw me. didnt know it was a skyline till i saw the badge. looks more like the new maxima or something.
what engines do these have? turbo? i know i could google it, but meh.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2604721
ok, i cracked and googled, lol.
3.5L DOHC V6 NA. meh. i dont really like it. very family/maxima. how can they call this a skyline????
VQ35DE (NEO) type V 6 cylinder DOHC with an X toroid CVT 8 speed transmission.
It's more than worthy of the skyline name and is totally different to a maxima.
I parked mine next to a maxima the other day and they look totally different.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606849
id get the coupe - but its similar to the 350z i reckon.....bah just slap on a turbo when modding it - works well either way....
Edit - ok maybe interior is not that much like the 350z - i dunno...gives me the impression that one of them was trying to copy the other....
Edited by emsta2003
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606996
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
