Hello all,
On the freeway tonight going slightly up hill I put my foot down in fourth gear.
As increasing speed the car started to jerk like a mule and the engine light flickered on and off for about 2 seconds.
Looked at the PFC handcontroller and had 75 reading on the knock sensor.
I have been having some mis-fire problems and it has lead me to believe I have a faulty AFM.
Just wanted to know if it could be something else ie TPS(Throttle position sensor)?
Any ideas?
Thanks in advance
Tekin :)
https://www.sau.com.au/forums/topic/139275-knock-sensor-went-to-75-help/
have a read of the powerfc faq in my signature
covers all of the common questions and howto's for working with knocking problems.
i don't believe its a any of those and just a few points have some timing thats a bit too advanced.
in the warmer weather its knocking a bit more and also when you place the car on load, typically when rpm is low and you up are going up a hill youll find via map tracer
that you may be going into map areas that you dont often go into, or that haven't been tuned correctly
as its hard to go over the entire map on the dyno and cover all scenarios, so it could just be 1 or 2 spots with a bit too much timing
Thanks for the replies boys,
New Pump,new regulator,new coils ,new plugs..........
I do suspect it to be tune or Afms playing up.
Still missing everyday even after earthing the ignitor.
But then again could be a few things.
:laugh::woot:>_<:glare:
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
ADJ for IGN COR will change to -3
Try and drive around and see if you can replicate the knocking / misfiring.
When you power the car off this correction goes back to 0 (zero). This is by design and how its meant to be. It's here as a test/tune mode and not meant to be a permenant correction method.
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
I will give it a go tonight on the way home and in the morning tommrrow.
Thanks Paul........just about to ask you what number in the FAQ...bit confused. :D
yeah whilst there is no "heres how to temp ign adjust" in the FAQ its covered in there. the problem is theres no english manual thats upto date so you either have to use the old school rx7 english manual or the japanese one
-3 means 3 degrees retarded timing
+3 means 3 degrees advanced timing
to help combat knocking, you can try and take out some timing (retard) to see if it takes away the knocking (usually does). try -3 which is 3 degrees retard across the whole map
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I've had motors where I have had it, and they where knocking very loud, like a rattle.
By the way, you won't do any damage as long as you:
1. Don't hold it there, or push on.
2. Get it fixed promptly so that it doesn't happen again.
3. Use a trailing throttle when going up steep hills etc keep the load off the car [although if you retard the ignition by 3 degrees then you'll have to still try it again to see if it's fixed it].
I'd be interested to see if it solves the whole problem. Maybe the 'lean out' has shown up another fault only showing up under stress?
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I'd like to learn.
The Op's has been having a miss problem; likely to be related to ignition. Your ignition system clearly is perfectly fine and your det is simply too much ign. :D
As I mentioned with shagged coil packs on 2 different cars I have observed an increase in knock over what was before a perfect low knock tune in all conditions.
Most likely not the case here and most likely just a tune issue. But I thought it would be usefull to mention it. :)
75knock really is too high, might be worth taking the car back for a touch up as a load condition may have been missed when it was on the dyno. It is difficult to simulate road conditions on a dyno; which is why its so important the tuner takes it for a quick spin. From what I've seen the dyno tends to miss partial throttle on boost load points and low rpm high gear (up hill) lugs where it makes reasonable boost; even though on the dyno we did hit these load points on the road it was 'just different'.
also tekin, when you are seeing these knock levels what is airtemp under monitor? you can set ign retard in the PFC based on airtemp's but its only for 70, 80, 90deg plus. so if its 55deg theres no correction
Thanks again guys for the remarks.....
Set back ign as paul indicated......car runs smoother and has not missed tonight.
Even going up hill i planted it and all was good...excellaration came on nice and strong.
Paul, can I set back the ign by -2degree permanently and see if it happens again?
Should I use one of your saved tunes instead and modify it to my mods?
And has the tune been conducted in colder weather and this is why this has happened?
Lots of question...... :(:):(:):(:):O
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
