Hello all,
On the freeway tonight going slightly up hill I put my foot down in fourth gear.
As increasing speed the car started to jerk like a mule and the engine light flickered on and off for about 2 seconds.
Looked at the PFC handcontroller and had 75 reading on the knock sensor.
I have been having some mis-fire problems and it has lead me to believe I have a faulty AFM.
Just wanted to know if it could be something else ie TPS(Throttle position sensor)?
Any ideas?
Thanks in advance
Tekin :)
https://www.sau.com.au/forums/topic/139275-knock-sensor-went-to-75-help/
have a read of the powerfc faq in my signature
covers all of the common questions and howto's for working with knocking problems.
i don't believe its a any of those and just a few points have some timing thats a bit too advanced.
in the warmer weather its knocking a bit more and also when you place the car on load, typically when rpm is low and you up are going up a hill youll find via map tracer
that you may be going into map areas that you dont often go into, or that haven't been tuned correctly
as its hard to go over the entire map on the dyno and cover all scenarios, so it could just be 1 or 2 spots with a bit too much timing
Thanks for the replies boys,
New Pump,new regulator,new coils ,new plugs..........
I do suspect it to be tune or Afms playing up.
Still missing everyday even after earthing the ignitor.
But then again could be a few things.
:laugh::woot:>_<:glare:
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
ADJ for IGN COR will change to -3
Try and drive around and see if you can replicate the knocking / misfiring.
When you power the car off this correction goes back to 0 (zero). This is by design and how its meant to be. It's here as a test/tune mode and not meant to be a permenant correction method.
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
I will give it a go tonight on the way home and in the morning tommrrow.
Thanks Paul........just about to ask you what number in the FAQ...bit confused. :D
yeah whilst there is no "heres how to temp ign adjust" in the FAQ its covered in there. the problem is theres no english manual thats upto date so you either have to use the old school rx7 english manual or the japanese one
-3 means 3 degrees retarded timing
+3 means 3 degrees advanced timing
to help combat knocking, you can try and take out some timing (retard) to see if it takes away the knocking (usually does). try -3 which is 3 degrees retard across the whole map
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I've had motors where I have had it, and they where knocking very loud, like a rattle.
By the way, you won't do any damage as long as you:
1. Don't hold it there, or push on.
2. Get it fixed promptly so that it doesn't happen again.
3. Use a trailing throttle when going up steep hills etc keep the load off the car [although if you retard the ignition by 3 degrees then you'll have to still try it again to see if it's fixed it].
I'd be interested to see if it solves the whole problem. Maybe the 'lean out' has shown up another fault only showing up under stress?
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I'd like to learn.
The Op's has been having a miss problem; likely to be related to ignition. Your ignition system clearly is perfectly fine and your det is simply too much ign. :D
As I mentioned with shagged coil packs on 2 different cars I have observed an increase in knock over what was before a perfect low knock tune in all conditions.
Most likely not the case here and most likely just a tune issue. But I thought it would be usefull to mention it. :)
75knock really is too high, might be worth taking the car back for a touch up as a load condition may have been missed when it was on the dyno. It is difficult to simulate road conditions on a dyno; which is why its so important the tuner takes it for a quick spin. From what I've seen the dyno tends to miss partial throttle on boost load points and low rpm high gear (up hill) lugs where it makes reasonable boost; even though on the dyno we did hit these load points on the road it was 'just different'.
also tekin, when you are seeing these knock levels what is airtemp under monitor? you can set ign retard in the PFC based on airtemp's but its only for 70, 80, 90deg plus. so if its 55deg theres no correction
Thanks again guys for the remarks.....
Set back ign as paul indicated......car runs smoother and has not missed tonight.
Even going up hill i planted it and all was good...excellaration came on nice and strong.
Paul, can I set back the ign by -2degree permanently and see if it happens again?
Should I use one of your saved tunes instead and modify it to my mods?
And has the tune been conducted in colder weather and this is why this has happened?
Lots of question...... :(:):(:):(:):O
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
