Hey Guys,
the plastic part of my upper radiator is cracked. I was wondering has anyone got any ideas on how to fix it.
Like Sikaflex or something else?
I got a price from Natrad in Granville NSW....they quoted me $418 for an new copper core one.
Any ideas or alternatives?
Thanks
https://www.sau.com.au/forums/topic/139298-r33-gtst-radiator/
It has big pressure in there and unless what you do is extremely strong i doubt it will last long. Considering it holds the life of your engine in its hands i would strongly recommend replacing. Try wreckers, should be easy to come by. Its a GTS-t! They are like taxi's.
justjap sell aluminium ones for 400.
a cheaper alternative would be to replace the top tank.
i got a new top tank for my old honda for $120. just go into any radiator specialists and they should be able to fix you up.
check out east-west radiators in bankstown, 4 exceller ave. ph: 97901232.
Look around for 2nd hand radiators, from people wreaking their lines. Got my 2nd hand radiator from one of the sau members.
My top end tanks were cracked/leaking, you could see the white stains. And also coolent leaking to the ground.
  • 4 weeks later...
For your information;
Superior Radiator Services, Seaton Rd Moorbeank NSW
$160.00 for a new upper tank which includes testing the tank and flush etc...
$380.00 for a new calsonic radiator.
Labour is extra if u want them to install it.
got any info on the calsonic radiators?
thats cheaper than the just jap aluminium 40mm ones.
Calsonic are just the standard replacements, right? If so, then the aluminium radiators are definately going to be more expensive.
I second the re-core idea. Shouldn't cost too much. $200? It's gotta be done, unless you source a used one that doesn't leak... for a while at least. :(
second hand replacement is probably the go.
You can try mending it with JB-weld or something similar, though I only recommend this as a temporary solution. It's a fantastic product, I have used it a number of times on my daily driver
I have had good results with jb-weld on a metal coolant line which had started to split along a seam, i used jbweld on it and it's been fine for 3 months now, which is impressive given that it's a high-pressure line. I do intend on replacing it, but i check it every few days and it hasn't shown any signs of leaking or starting to crack again.
don't know if i would use it as a permanent solution for my skyline but it's good as a temp fix to get you out of trouble until you can afford to replace the end tank
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
