yeh im going either the gtss or gt2860 both make good power,and good response ive heard
Im thinkin of doin the same there Gunner i was sweatin on the GT_RS's but from what ive heard the 2871's might be the same laggy but good power from 4grand onwards
Hi mate i have them on my gtr and it made 510hp at the wheels on 22psi and 345kw on 17psi at the wheels they come on boost around 3000rpm and make strong power all the way to 8000rpm they work great with the right set up i have all the dyno sheets if you need any more info drop me a line thanks Jason
what else have you got in your motor?? stand 2.6L? cams?? see 3000rpm is not too bad...care to share a bit more?? cheers
thanx guys, just i thought this thread was dead
coming on boost is what? = 1psi, 20psi?
Loaded up on a dyno on 4th or on the street?
There is no way your going to see anything decent before 4500rpm on a stock capacity RB26.
They are 400hp turbos, not 300hp GT-SS or that ballpark turbo
Again, is that loaded up in 4th on a dyno?
Or are you seeing this sorta thing with a roll-on in 3rd.
Its hard to gauge and compare the two as they are totally different to each other.
Not saying your results are false or whatever, just trying to get an accurate picture
frankxinyu - whats your use for the car?
as topic states, is anyone using twin Garrett GT2871s on their GTRs? if so, how laggy are they? and what kind of power are they putting out?
cheers guys
frankxinyu the garret Gt2871 are basically the HKS GTRS turbo and are quiet common on the rb26 but they have had mixed results. They do make more power than the 707160-5 gt2860r but not by much and the turbo responce loss i believe doesnt out power gain. The best results gained fromt the HKS GTRS/GT2871 have been on stoked rb27/28 or rb30. You find it hard to beat the garret Gt2860R 707160-5 or HKS 2530 for alround twin low mount turbos.
Pete
This is the -5s at only 17psi with basic tune as the injectors are 100% duty so by the time we fit bigger injectors and run 24PSI with a full tune i really cant see the point in looking past these turbos for a dual use car and the price it right. RB26 std stroke and head,260Poncams and single throttle kit on stock intake so the engines not wild,shows how good the turbos are.
Boost controller is now sorted so boost is now earlyer and flatter.
i do wanna maintain the street drivability, but it will see some track days.
by talking to another owner who is running twin GTRS on his stock RB26, these turbos are way too laggy on the street....i think i am going to stick to GT2860s-5
thats awesome figure....
the thing is these 2860s are so cheap nowadays.. they are cheaper than the GTSS ones, yet still make more power.....
To a large degree the jump from a 60mm to a 71mm compressor is going to affect the boost threshold because you have essentially the same sized turbine and housing with the same exhaust gas velocity trying to spin them up .
Lots of people ask me what is the next step up from the bigger trim 60mm compressors ie 2530's 63T or the high tip height 60mm 62 trim from the GT28RS/2860RS . So next up in Garretts GT range is the 71mm wheels (GT 35 comp series) which my list shows three sizes .
1) 71mm 48T , 49.25 inducer diameter , 4.75 mm tip height .
2) 71mm 52T , 51.20 inducer diametre , 5.00 mm tip height .
3) 71mm 56T , 53.10 inducer diametre , 5.00 mm tip height .
The larger trim and exducer tip height wheels have greater pumping capacity but it comes at a price , moving more air for the same wheel rpm means they need extra power to drive them . If the extra shaft power is not available then we need more engine revs giving more exhaust gas velocity to power the turbine/s . Basically the big trim/tip height wheels with the same turbine force a slip loss effect of the exhaust gasses round the turbine blades . Its a lose lose lose situation because boost threshold goes up , exhaust restriction goes up , detonation threshold comes down - backpressure if you like forces exhaust gas reversal back into the chambers in the overlap phase so charge dilution and preheating as well as pumping losses . All biggies .
Note in (1) above that the 48 trim 71mm wheel has obviously a smaller inducer diametre size AND lower exducer tip height . This is the next incremental step up from the 60mm GT compressors and will generate a bit more airflow (maybe 3-4 lbs) but have the least negative side affects of the three 71mm compressors . I don't think I'd go past this stage if at all on a standard capacity RB26 because its already starting to turn laggy and getting a bit hot and restrictive on the turbine side if really pushed . Probably more to be had from porting and cams with less trade off . 2860's and 2530's seem to be the sweet spot and after that really need larger turbines to compliment the larger compressors . This then really pushes the boost threshold up and increased capacity is the only way to help bring it back down .
Cheers A .
Edited by discopotato03
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
