hey, i just found out quite alot of oil is leaking into my coolant and i was wondering if you guys could help me out by telling me what you guys think. Ive taken the car to a mechanic and they reckon it could be either a cracked head or a crack in the block, both these are an expensive option to repair. Would it also be possible that the head gasket may have something to do with the problem? eg over tightning etc..
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/
Not common to crack the DOHC heads.
Most likely a headgasket.
Are you sure its oil and not just sludge build up from the lack of coolant changes. When I first bought mine close to 5yrs ago, cleaned radiator, a block and heater core flush by myself with good new coolant never got rid of it.
Dropped a new motor in it and the sludge crap was still there. Gave it a power flush and it came good.
There must of been a heap of sludge in the heater core that my garden hose couldn't get out. :laugh:
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2600898
when i took it to my mechanic, he said he flushed it a few times and was still able to watch the oil flow through the coolant in the radiator
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601091
if the car is an auto...the radiator might be stuffd inside letting the auto fluid mix in with the coolant
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601098
How trust worthy is this mechanic?
Is he a well known performance shop?
Grab a second opinion.. It could save you quite a bit of money.
Chances are if you are getting oil in the water then you will also get water in the oil as when you shut the car down the cooling system pressurises while the oil is un-pressurised
In the past with cracked heads on VL's I usually see water in the oil up in the pvc valve before I see water in the oil, when left long enough you then see the white crap (water) under the oil filler cap.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601293
is there water in the oil or just oil in the water? i have had oil in my coolant only prob before. have u got a workshop manual for the car? look up the pics of the oil setup between the oil filter and the block. there is a sandwich plate round factory oil cooler/transfer unit. theres a coil running through it that passes the oil from the block to the filter. coolant runs around the coil. the coil in mine had corroded though. cos there was more pressure in the oil then coolant, i only had oil pushing into the coolant... its a bitch to get to but its possible to change without takin off the plenium. a lot cheaper then lookin at head gaskets.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2602678
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
