Hi Guys,
I have recently been having problems with my 32 gts-t. Basically under hard/full acceleration the car was flat spotting where it felt as though petrol was not getting into the engine properly around 4 - 5.5 thousand rpm.
First my mechanic tried a fuel additive which seemed to fix it but then it slowly returned. Then got the injectors ultrasonic cleaned. Again, seemed to fix it despite the fact that when i got it back the car had serious problems starting which it still does. 2 out of 3 times i hold it on start while its turning over and over and doesn’t come to life. After a second try it splutters into life. Now the flat spot has returned again.
It has cost $300 with additive and injector cleaning so far and back where i started. Also, it also does not idle well, specifically when pulling up to lights and selecting neutral while rolling to a stop the revs nearly drop to 0-100rpm. I stop and it comes back up, goes down, up.....
I have a feeling from what I have read on these forums that the problem may be related to the AAC valve but I would appreciate anyone who could offer any advice.
Thank you in advance!
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/
chked ur fuel pump?
Yeah that was one of the next things I felt could quite likely be a cause of the problem. But I was wondering if the AAC valve is (and im not sure if this is so) causing the idle issue could that have any relation to the flat spot?
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2603706
You haven't stated if the engine has been modded in any way. Info like that is often useful in diasgnosing these sorts of problems.
Idle "hunting" is likely the AAC valve - it's the little cylinder attached to the back of the plenum chamber.
The flat-spot is totally unrelated to the AAC valve. It is likely the ECU is detecting "knock", which may be caused by a dying fuel pump. Get the car onto a dyno, with an AFR meter and a fuel pressure gauge.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2603857
AFR = Air Fuel Ratio.
There isn't a meter for this in the car.
The car monitors Air flow = AFM (Air flow meter)
and from this and other factors (tps etc) determines how much fuel to put into each cylinder at various revs/load etc.
The car also has a o2 sensor which tells the car essentially if the car is running rich or lean.
If you want a proper AFR you'll need to get a wide band AF gauge and probe. Very good tuning tool, lets you know exactly whats going on with your AFR's.
You know when you see people getting their car tuned on a Dyno, and they tuner's got a probe sticking in their exhaust? This is what that is.
Sounds like your problem is fuel issues, either too much or too little.
Generally the more mods you do to a skyline the richer they run. Richer=safer (away from detonation) but also means retarded as far as power use goes, and fuel economy goes down.
It could also be fuel starvation= Ie, dying fuel pump, blocked fuel filter etc.
This is the most dangerous of all senarios, if this is the case, get it fixed soon.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2605760
Thanks for the replies.
It's all very confusing. Im a bit worried now, I will have to minimise my use of the car from now on cause I am really busy with uni/wrk so cant get it looked at atm. The only day I have to use it is wednesdays, every other day i can get lifts/use another car or p/transport.
At least I know a few things it could be know. I hope i can find out for sure what the problem is.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2607780
Just to add to that,
When I just drive the car normally (as in not rev beyond 3,500rpm) it is 100% fine and drives smoothly and without problem, other than the issue of getting it started... So this wednesday and next I assume that it wont be doing any damage driving like this??
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2607825
Guest tosboost2
ok to start i know on this forum that this guy says do this, and another guy says do that. so i dont care if u listen to what i have to say
but anyways i had the same problem with my 32.
i spent 600-700 bux diagnosing the problem and changing things, taking the car places etc.
it ended up being my afm was dead, so i got a new one, and the seal around my blow off valve was busted, i dunno how that made much difference but i fixed that, i still have a few problems but only when the cars cold, which is the cold start valve. and seeing as i cant find another one ill have the problem for a while.
find someone else with the same afm as you and just swap them over and see if that helps :laugh:
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2621547
find someone else with the same afm as you and just swap them over and see if that helps :)
Thanks for your help, my mate has a 32 gts-t like me, so I can try that then and ill put in a new petrol filter if that doesnt work and see...
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2622517
  • 3 weeks later...
Well for those who are interested... PROBLEM SOLVED
After being introduced to a friend of a friend, we got talking, and I found out he owns an r32 gts-t also, and is a mechanic!! He had rebuilt his rb20det and knew a lot about them.
Took my car to him and he discovered a pipe connected to the fuel pressure regulator was split in 2 places and barely hanging on. Replaced that and he raised the idle and it was fine, revvvvs out beautifully and sits perfect at 800pm at idle and doesn’t fluctuate.... all this fixed for next to nothing, meaning the $300 spent to date was wasted... at least its fixed !!!!! :pirate::):yes:
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2671185
which "pipe"
can you put up a pic of an engine bay and point to it?
cheers,
Warren
PS did it also help with the starting issue?
Yeah its pissing down outside now, but next available chance i will take and post pic, and yes it had serious issues starting sometimes, others it would be fine, but more often than not id have to try 2 or 3 times... all good now :P
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2671595
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
