Hi,
I've got an R33 4door completely stock standard. I recently had the front brake pads replaced with Bendix and everything worked fine for about a week.
After that the brakes were different from drive to drive ie. sometimes they'd require the lightest tap and they'd pull up, other times the brakes wouldn't work until you get to about 1/2 way down the pedal. The missus reckons at some point she went flying through a stop sign because she couldn't stop :D !!
At the moment, they've stopped changing from hour to hour and are left feeling really weak, like you have to get the pedal 3/4 of the way down until they start to work, then they pull up fairly well.
As far as I can see, there are no leaks, and the rotors and calipers are fine + before the new pads were put in everything was working honky dory. Any suggestions guys?
The other thing is, the r33 pads wouldn't fit my calipers, they were completely different, I found out that I have r32 calipers. Is this unusual for a '94 R33?
Cheers
Matt
https://www.sau.com.au/forums/topic/139783-brakes-spongy-help-me/
to check if pistons are working fine, push them back with your fingers if they are too hard that might be your problem, thats what my brake specialist told me, am having big dramas with my brakes squeeling but can't figure it out
does the car pull to one side when braking? that will rule out a binding or stuffed piston probably.
-check for leaking brake fluid at calipers, brake lines and master cylinder
-check for kinks in the brake lines
-bleed all 4 brakes, replace the brake fluid completly if you feel the need, also check that all the lines are tight and the bleed valves are closed properly.
if it is still having problems after bleeding all 4 brakes, and the pads are installed correctly and no massive run-out on the rotors, rotors are above minimum thickness etc. then it's probably going to be a rooted master cylinder.
(also, remember to follow correct bleeding procedure especially if you have ABS brakes).
air in the lines is the usual cause of spongy brakes, did the resoviour get run dry for any reason? did you crack the bleed valve by mistake? did you loosen any of the brake lines when removing the caliper?
Edited by MerlinTheHapyPig
had the same problem and that solved it!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
