Low Boost Pressure
Guest Lojikl
Okay this has been bothering me for a while.
My boost pressure seems fairly crappy. Even when I hammer the accellerator the boost NEVER goes above about 3.5 on the standard boost guage, and I can feel that theres not much jump in acceleration.
I have a Pod filter and 3 inch cat back exhaust. My old 180SX used to hit 15 no worries,
Anyone have an ideas what might be going on here.
Cheers.
https://www.sau.com.au/forums/topic/13983-low-boost-pressure/
If you want to increase the boost there are 2 way, bleed valve or an electronic boost controller. Some EBC's have a boost gauge built in (blitz dual sbc) which will tell you how much boost before manifold. The bleed valve is much cheaper but will spike so you'll need to get yourself a seperate boost gauge to read what boost you are running. Eitherway is effective, just dont run more than 13psi through the stock turbo. Plus if you still have the stock intercooler you wont be able to run that boost all the time without having some detonation when the temperature is warm. Comes down to how much you want to spend and how reliable you want it to be.
Nothing like setting my EBC to 12psi on a cold night like tonight and giving it a good fang on the way home from some crappy training session at telstra ;) Even with the stock cooler on a cool night like tonight I found I could run 12psi without much problems but with the front mount now it does seem to pull a small amount harder.
my r31 only reads around 3psi on the stock guage as well, fitting a better boost guage soon to suss it out.
rev210, in saying thats normal is the factory guage out or is the car just running bugger all boost?? cheers mate
with the stock intercooler and 12psi on a 30+ degree day the car would detonate when pushed hard because the intake temps were so high, detonation sounds like a rattling noise coming from the engine and will cause severe damage to the engine if you keep pushing it, if you hear it stop pushing the car and back right off. Now I can pretty much run 12psi on a hot day and push it hard without too many drama's but I dont like to.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
