  • 1 month later...
ha ha ha yea i was hoping for a break between weather, and the pot holes are unbelievable! i cant see the australia day drags being on either! and to add to the annoyance the police are an over kill this time of year.
hey all, im also in mackay, have a r33 s1 gtst black , currently in the processing of respraying, just sanding it back atm
callan, seen your skyline driving around, must say nice skyline bud
Hi There
I have been in mackay for friggin ages, have owned a few skylines in my time. Currently own a R33 GTR and My lil brother Matt owns a R32 GTR N1, you will see us at the strip quite a bit this year as we will be trying to get as much seat time as possible for the Jamboree in August. Aiming for a 8sec pass on Street Radials, but should do a low 9sec quite comfortably. Both Cars should be on the road in a couple of months, looking forward to doing some cruises with you guys through out the year.
Hells yeah, that would be awesome. I've seen you car around a few times... It's visual Porn. You've got a great car, lad. When Palmyra is dried up (In the next few weeks? Haha) give us a yell on here if you're going to the TnT and I'll make sure I'll be down to watch you.
Thanks mate yeah wont be dragging the r33 anytime soon lol let me rephrase that my lil bro wont be dragging it as he broke my gearbox. Its still pulled apart and gotta take it to brissy for a tune 400-450rwkw hopefully. R32 will be getting dragged religously but.
It'll never dry out lol
No way, I'm not wasting my last day of holidays doing that lol.... Did you end up getting your power window module fix? Mines playing up so might pull it apart and re-solder if it looks dodgy. Id say thats all thats wrong with yours as well
Hey my power window on the drivers side is playing up aswell i think its just the contacts in it, does anyone know if we are gonna organise some imports vs V8 nights at the drags this year would like to try tee something up it would be kickass!!!!
I'm keen for a drag when my new wheels get here, but I'll race anything, I just want to see what time I can get.
As for the drivers side window thing, theres a thread in the DIY section I'm pretty sure on how to fix it, Im gonna give it a go soon, was gonna do it a while ago but opened the box for my power window up and everything looked good. Supposedly only takes about 5 mins and a bit of new solder
Took some photos of my engine bay today..... a good camera and some lighting really shows up how dirty it is :( lol
Give me a call when you do yours, Cal and I'll head over to your place with mine and see if that works... Slack to fork out $250 if it just needs new solder. :)
I demand a rematch on GT5... I regeared the shit out of my R33 GTR. I want my redemption!
Airlie sounds good (and is better then halfway) lol
Rob: you were useless :P I'll get my carbon R out for a rematch lol. Yeah I might get keen to play with electrics this weekend. Bring your black box and I'll see if there's any noticable dry solder.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
