I think I know a little about this car. If the plates are still on the same car that is. But there was a blue r34 in Adelaide with these plates in around 2003. It was stock engine and turbos making about 260awkw with an exhaust and power FC. So yeah I would really doubt the claims of it being a 2.7 built in Japan!
I heard back from the guy with the SIL80 last night. He's doing the KA24 with twin TD06 turbos now. Insane?!?!
sounds like it will be a weapon for sure... wonder if he will let me have a look at it when its done
What ECU do you run, Force? Or just a standard?
I'm still waiting for Dysonest to get his ass over here and help me decide on what I want.
But yeah, apparently the RB26 D'Jetro splices pretty simply into the KA24 system. Almost nearly just plugs right in.
Actually, I even modded one to run my mates r32 gts-t and it was still simple. Barely any cutting or soldering.
the mafia is deffinately the person for the job by the sounds of it
Keep it up, you can pretend that you are cool. But you really must fail at life. I'm glad constantly trying to be cool on a forum makes you feel a little bit better about it.
If I wasn't such a calm person, I would have ended up punching you in the face by now if I knew you or met you. But, instead I'll just feel sorry for you needing to make up for your shortfalls.
Good luck anyway. Your mouth will catch up with you, not all people are smart enough to control themselves like I can.
Edited by The Mafia
Reminds me of a mackay guy that said his RB20 was a forged 2.4 stroker. Sold it as that too. Engine died and my mate obtained it for parts. Was a 100% stock RB20. NOt a single bolt touched on the engine. Probably not even for servicing.
Powerfc mate L-Jetro, Will be getting removed and swapped for a Haltech Platinum Pro plugin at end of year. Needs the nismo AFM's if I wanna push the turbo's to their "potential" without issue..... or I swap to ecu with MAP sensor.... :)
Depends on who you want to tune it mate and what your needs are really..
Yeah, I've heard that too! LOL
Trained for 10 years. I think that's enough for me.
But you're just a smart mouthed dickhead that has read a few forums. I bet youve done f**k all actual modding. If any at all.
I don't know what you're trying to prove either, you keep coming back here. Must have a boring life.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
