yea i think your right there, just putting cash aside now for t400 auto box and trans brake so im expecting to break diffs and axles more often when i get it all in the car. i found billet axles for my car rated to 1000hp for 550 delivered so if i break them again ill just upgrade. diffs i have just not axles.
Are they for Gts-t cause I only ever find GTR ones which I assume are longer?
Debating wether it's better to have the driveshafts as the weakpoint or not cause if I get stronger ones it's only gonna be something more expensive that will break instead......
Driveshafts should not break if the suspension is setup properly, the only other way they will break is fatigue from doing a million launches in them. If you have have really hard spring rates like 7-9kg/mm on the rear well that is way to hard, and if your car gets axle tramp when the wheels spin well that will also cause it to be weaker. Personally i don't know if GTR shafts are longer than GTS ones but i'm gonna guess and say they should be the same. If you are gonna be drag racing the car all the time then its probably worth spending some coin on the rear end suspension getting it right so when the car squats for a launch the driveshafts are as straight as possible. + dumping the clutch at 6000-7000rpm is not good either as this shock loads the whole drive train, in GTR's when you dump the clutch at 8000-9000rpm all the time i guarantee you will end up breaking something really quickly, need to side step the clutch by releasing the pedal slowly and letting the clutch grab slowly it might just save the drive train a bit of shock load. I see people all break shafts all the time, i've owned skylines and GTR's now for 6yrs + and have never broken a drive shaft yet and i thrash the shit out of my cars ask Kingy he can concur with this lol thumbsup.gif.
Haha yeah. I think my driveshaft that snapped was a bit of a random thing. Ask anyone I don't really do hard launches around town, I'm a girl and all that shit yeah yeah :P
But it's always in the back of my mind now, I'm mainly worried about if I ever get semis. But I need to slip the clutch a bit next time I go out for a run. The button clutch won't make it easy but I'll manage :)
cal, I did stacks of drags and launches and stuff, and with semi slicks and never had an axle problem. I think your problem was a bit of a fluke.
Also, always let the clutch out, never side step. Too much shock, and you'll only create unwanted wheelspin.
Does beat the shit out of it..... When its not parked up being worked on lol...:P
Ben, would t waste your time with the dirty thirty.
You're better off with the dirty whore, thirty four. Haha.
The rb30 cranks are a bit old to be spinning hard. The rb34 kit from spool has a billet crank in with the package. Costs $5k. Spin the f**ker to 10k and bolt twin gtx3071s on it, haha.
You need to set the record straight with the xr6ts ;)
Ah i got 2 RB30 blocks at home a shitty N/A block and a Turbo Block, should just sell them and spend it on my N1 engine or sell the lot and twin turbo the Z, hhmm never own 2 good cars it just makes it harder to figure out what to spend the money on.... someone buy my GTR i'm sick of looking at it.
the NA blocks are just as good as the turbo blocks (exactly the same) if they are a series 2 block. They have the oil and water lines for the turbo. Just bunged up.
I'd use one for the RB34 ;)
How long do you think Cals engine would last with the TO4Z on it? haha.
Lol Stock RB25 with T04Z = LAG MONSTER i'd give a week before it would blow a piston and rings to bits rolleyes.gif
I remember my mates R34 GTT i built for him with a GT3540 on a stock engine, damn that thing had bulk lag but was awesome fun on boost.
Seen an RB25 with a T04Z (all be it not as new design as the one you have) and yeah..... No thanks lol
The only reason I went HKS was for good mix of power and response, would have been more then happy with the Pro S. I'm sure of that
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
