that 370z looks sweet as! i like the colour and rims. benny when you pimp your 370? got the twins turbs
for it yet?
Lol nah i got a HKS single turbo kit sitting in the shed, gonna forge the bottom end and run it on E85 should be able to hold its own with the supra's and GTR's thumbsup.gif
Nah not kidding need the money for a house and wedding will buy a new car after i get a house, in the mean time i was planning on stripping my N1 engine putting a 2.8L stroker with V-Cam, ported head all new valve train, new tomei Arms M7655 Turbos etc and later on maybe next year i want to import a bog stock mint condition if i can get one R32 GTR preferably Vspec 1or 2 and keep it clean and simple restore all the f**ked parts on it. I just want a fun daily/weekend car which is what Dads R32 was before we turned it into a monster, it was the most fun/fast/responsive street car it only had 280kw but f**k me it was quick, no lag + the R32 is a real drivers car a lot hard to tame than is bigger brothers.
Something like this simple yet so very tuff:
Hey's guys thinking about selling my 350Z if anyone is interested, i want to buy another GTR later on probably import a fresh one from japan again.
Make up your mind already :P
How was your new years? We had a pretty quiet one really, didnt pan out how we thought and ended up home before 12 lol.... oh well
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
