forgot to add it has to have 30 spline. ei from a 34 or s15 but seen as s15 were a 6 bolt it needs to be from a 34 pinch.gif
are you sure the R33 ones arent the same? I dont remember the spline count but pretty sure it was around 30
I have a RHS drive shaft spare btw, I'm not sure if its the longer or shorter one, just found a photo of the old one and it has LHS written on it and I got sent a RHS one the first time so have a spare
New seats might be here tomorrow before I go back out to work with any luck. Or its 7 days out there waiting to see what there like to sit in lol
Ordered a cheap HID kit as well..... Must stop spending money..........
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
