I talked to a guy from Meng in the main street, he was very helpful and i brought up wheel allignments and he replied it can be done in about 2-3 days. Pedders in north mackay have a huge wait, 1 week +
and from memory i think an allignment is about $75 from Meng.
Ok so i need to replace the bolt in my front left, rear castor bar (behind the disk brakes) and it's basically impossible to do it from home as the original bolt is extremely tight and there isn't enough room to get a good go at it from being jacked up.
I need some advice as to who to go to to get this done,
Nissan have said "we don't have the equipment" the chick at the counter must have been drunk.
Pedders want $140 P/H and can't do it until next week sometime, although it should be roughly an hours work i still don't want to pay that much. I haven't tried anywhere else yet but i wanted to know if anyone has had this done before and could recommend a place or an individual to do it.
thanks
Just think about this. If someone does a job well, everyone wants to go there, if someone else doesnt, then there not going to have a huge line-up of customers
Personally I'd rather take it to neither. Would like if I knew someone who worked at a mechanics shop with the alignment tools to do it. But I dont know of anyone.
Not trying to detur you from Meng's, but just saying that something that seems like a good thing can turn out to be a bad thing
I went to pedders last time, and it seems to have helped my tyre wear so cant complain to much. However I dont think they took any camber out of the rear.
So I haven't spammed the thread with photos for a while so I thought now would be a good time. Spent some time today straightening out the diffuser after slamming it on the gutter at south Mackay KFC the other day (or at least I think thats where I bent it up)
Gave the car a wash and had a play with the camera for the first time in a little bit.
I really like taking photos with alot of depth. bit like this where only one section of the photo is completely in focus
And one from a while ago:
Engine bay is so clean, nice pics man
Cheers. Its a bit messy at the moment but its come along way, seen as it looked like this about 3 months into owning it:
Anyway. Did a quick before/after photo of what can easily be done with 5 minutes in photoshop. Removed stone chips from my front bar and did some processing. Yes yes I'm bored on my days off........
Impressive man, in 3 months that's a really big difference. Also did you go through four ways at like 6am, I'm almost 100% sure it was your car that i heard when i first woke up haha.
haha no 3 months into owning it. so about 5 years ago...
And i was out at about 6:30 but not through four ways
Hey guys finally got another car to flog/build. Picked up a early model 180SX off of Rob in Townsville. Goes alright but you know me guys this thing will begin its transformation ASAP, i will be ordering a ship load of parts when i get home next week. Can't wait to hit the prossy track and hang the arse out will be freaking awesome.
Here's some pics:
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
