Yeah there is a S14 with the KF's floating around town, but its ok i'll let ya take all the glory bro lol :woot: . But i have the same origin over fenders, i already have +25mm Front and my +50mm rears got posted today, just waiting for quotes on rims. Still haven't decided on body kit yet
i bet his arent as baller as mine are. :whistling:
WHAT THE f**k HAVE YOU DONE....
ur dodgey wiring??
no dodgey wiring in my car mate.
happened at a workshop, welding earth arked out on some wiring .
wow sad to hear Rob. Any ideas on fixable? or what caused it?
fixable, workshop is going to fix it but may take a while. need another cars whole interior plus gtr seats, defi's, stereo, profec b, front widscreen ,window tint, some window trims and we still haven't seen under the whole dash yet.
but it will be back bigger and better, got some brembo's on the way and factory aero kit to go on :)
Edited by dysonest
Can anyone recommend a place to get a decent tune? I've heard to stay away from Monster performance.
I'm running Injen CAI, Kinetix V+ Upper Plenum & soon to fit an exhaust so i want to get a tune done before i go to Townsville in December to get the air/fuel ratio back to normal and a bit more power.
Thanks
Don't really think it will need tuning i had Injen CAI, Motodyne Plenum Spacer and Fast Intension Dual Cat Back Exhaust on my 350Z and i never tuned it and it ran awesome, i also had the rev-up engine in mine which has extra 15kw form factory dunno if that would have made a difference. It's not a Forced induction car so doing those mods will not have a huge effect on the power level and getting it tuned will not do a great deal for it.
This was my initial thoughts but i had a friend recomend get a tune after i do the exhaust. I have noticed since installing the CAI that my fuel is absolutely guzzling out :/
Mines decreased a lot, yes i pulled the MAF out of the stock intake and into the Injen system. Didn't have any problems though it was just straight plug in. I'm probably getting not even 500km off a tank now
dont buy a turbo skyline then :P
I could be wrong but I think Ben was talking about adjusting the AFM perhaps?
I know you could do this on the VL's
but if your dead set on getting a tune I think your better off waiting till you get to Townsville. There are a few workshops there that sound trustworthy, more then I can say for here
It's N/A bro. Yeah i think that's going to be the go i may just have to wait until then.
Not sure what you have done to it but i was getting 600-700kms out my Z when i had it 8.7L per 100kms in town/highway/thrashing it didn't matter.
Ahh really, that's roughly what i'm getting per 100km though. I will fill up tonight and do a test, all i do is to and from work and out to ooralea a bit.
Oh I just meant if your complaining about fuel economy now, dont get a turbo Skyline haha. I'm lucky to get 400km around town out of mine, but I think I have some issues at the moment.
Is your tank smaller then the 350Z's? Seems to be the thing most people forget about. Complain there only getting 400km around town but then only have a 40L tank.
Find someone with a standalone wideband and go for a drive with that hooked up. Will tell you how far out your cruise mixtures are.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
