Nulon is supposed to be good for the price. But I'm undecided at the moment. I've used Castrol Edge before, but didn't really like it. Hard to explain but the car just felt nicer when I went back to Motul
Got 5000km before I need to service it again, with work and the amount I drive that will probably be near 6 months away lol. Plenty of time to decide what I want to use
If anyone has a complete RB25 head that they want to offload for cheap let me know also
The car ran a PB on 9.58 @ 144mph with a 60ft of 1.4sec which i am pretty happy with. Willowbank will be the proving ground of its true potential. 0.5sec is what i am guess-ta-mating we will gain on track condition with the same 800hp tune at the moment which gives us a 9.0sec and Mark thinks that with a healthy tune on 36psi should get us the 8.7 - 8.8sec which will give us the record we have set out to achieve. Fastest Street Tyre H-Pattern GTR, but baby steps first as long as the car goes faster every time we drive it is always an achievement which is what it has been doing which at the end of the day is all we want.
The car is impressing us every time we run, we do very minimal changes and gain huge results which gives us massive satisfaction. The car is still full bodied all steel panels still only carbon bonnet at the moment and we have heaps of things to lighten the car up but at this point in time are just not needed, like carbon doors, carbon boot, remove intercooler, carbon brake rotors, Weld drag rims, Lexan windows, exhaust removal, interior strip etc. Which would gives us an easy 100KG + lighter.
The car also had its first major component failure, but was to be expected as it cops the brute force and shock load and has done over 40 odd drag launches and numerous dyno runs, and if you have ever owned a GTR the clutch does not last very long if you keep doing hard 4wd Launches. The engine and gearbox was removed yesterday and the clutch was sent straight to Doug at NPC to get overhauled and modified even stronger to full drag specification. While the engine is out we will check everything to make sure it is 110% before it heads of to Jambo. Bring it on I say :woot:.
Ben, that just means he didn't launch it hard enough :P
I just want a rough daily that goes fast, and looks ok, and has most of the annoying mods done. Not sure if I like red though.
What do you guys think of this? http://www.ebay.com....9#ht_500wt_1414
Trying to find something that isn't full of kebab wrappers if you know what I mean.
Edited by The Mafia
That's nice, i like that red Jono.
Nice work ben, just out of curiosity who would be best to see about gearbox issues? i am quite sure i have a worn 5th synchro.
Also i need to get my pads re machined, who would be best to see for that? heard good things about Borgs brakes and front end but never got anything done with them.
thanks
thanks
I do all my own gearbox work man so i cant really recommend anyone.
Do you mean your rotors need machining?
Have you looked how much new ones are? I got DBA rotors for mine for a bit over $400 for all 4. AFM pads are pretty good as well
Had a bit of a look around yeah, mine have plenty of life left so i just wanted to get the faces machined because they are a little lumpy and you can see lines on the face.
Just like to thank Jono again for hooking me up with Leon, took my V35 to him today to get my comp rod bushes replaced and he did a great job. So good to not hear that horrible clunking noise anymore after putting up with it for 5 months, that's how long it takes to find someone in Mackay!
i'd love to do my mown work just sucks that i dont have a shed or the gear to do most of the work, plus little knowledge is a factor haha. I'm not sure what i'd like to do maybe, forge the engine, get a new ecu and fuel management, larger turbo. i'd probably be happy with that haha.
I don't think there's any businesses in town that have the equipment to do a good tune but there's blokes with awesome setups in their home garage.. eg Leon. Has a hoist and everything and very knowledgable
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
