Cheap shit cheese cutters they use, then they say i can spin the wheels in 4th sounding all cool and shit, then i say how wide are they? Reply: 235's What brand of tyre? Reply: Nankang. My ride on mower could spin them in 4th you f**kwit go buy some decent shit ffs!!!!! :domokun: f**king Falcodore drivers are retarded.
I'm stealing this for my sig. lol!
I was watching the new episode from Mighty Car Mods last night regarding to speedo adjustment for when you buy new wheels-
I have nearly got my new springs/rims/tyres/camber kit and i was curious, once i install all of this is my speedo going to be out of whack with the different rolling diameter? I'm looking at going 275 R 245 F atm i have stock wheels im pretty sure front is 225 and rear is 245.
If so, where do i go to get my speedo adjusted?
Thanks
It depends on profile. If you know the standard Tyre size or whatever tires you have on now then you can work it out by adding the rim diameter and the profile. Profile is percentage of Tyre width (I think) so a 265/40 is 40% of 265 (equals actual sidewall profile dimension)
Google to make sure I've got this right but if you get this and compare to your current Tyre + rim overall dimension you can see how different it is. Work out the circumference if they are different.
i've just bought a new horn for my R33 as it was missing and i've checked it with a power lead and it works fine but it doesn't work with my steering wheel, anyone wanna fix it for me in mackay? willing to pay haha i'd do it but i'm lacking tools..
Off topic but are you on your P's Jake?
nope fully licensed haha, whys that? also i have accuried a set of Enkei rims for my R33 :woot:
Just curious, i was driving next to a black R33 the other night gave thumbs up then took off aha. Nice man! pic?
I should have these on my doorstep this time next week fingers crossed-
http://i45.tinypic.com/219tpp4.jpg
Edited by Seano350GT
you sure u've hooked it up right ?? 1 or 2 pin ?? and is stock 1 or 2 pin ?
one pin stock, hooked up, fuse is fine, think i have a s2 steering wheel maybe its been upgraded? as i think i have a s1.
haha they haven't arrived yet =P but these are what I've got; only 17" though.. also black centers
any one going for a cruise around mackay tonight? i was having a bit of a burn last-night but i have no idea where people drive around ie "Blockie Route"
I might go out for a bit of a drive. Thursday night everyone goes to the harbour, but there's usually a strong police presence just past mossies BP and on forgan bridge and they come down around the harbour too so don't do anything silly!
It's usually just the bogans in commodores and falcons though.
I'd rather sit at home and drink piss and work on my car then go out hooning on a Thursday night and look at stock cars with bolt on BOVS and cheap shit chromies, don't mind me But I'm a alcoholic lol.
i have no idea where people go haha i've hardly been anywhere appart from work and home haha i'll probably go for burn tonight, also i have a set of stock rims with kumho KU36 not sure on there condidtion but they have no gutterrash or anything and i dont want them haha what are they worth anyone wanna buy them? also have a set of stoc rims with unknown tires with out the centers that are on my car now that i won't need soon..
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
